Home > Puma (Tdci) > What does your 2.2 engine sound like?
Page 1 of 3 123>
ncow84
Hi folks,
New to the forum here, have been reading for a while though and thought I'd finally get a post in.
I've recently bought a MY15 90 XS, as a replacement for my 17yr old 300tdi (old faithful), unfortunately it's not been plain sailing, I'm on my 4th visit back to the dealer in a month, and, amongst other issues, every time I've complained about engine rattles under load. I'm now sure it's not in my head as passengers have mentioned it. It's similar to posts I've read already regarding pinking type rattles when up to operating temp, however my suggestion to the dealer that injection calibration may be out was met with a puzzled look. It's been returned to me every time with the usual 'they all do that, sir'. How infuriating.
I've driven plenty of 2.2 Defenders now, some have been very refined, some have rattled a bit. Mine seems to be dreadful.
So my question, what are yours like? What SHOULD the puma engine sound like, at idle, under load, when cruising?
Mine makes a ticking type rattle under most conditions. That can't be normal...old faithful certainly never sounded this rattly.
I had such high hopes for the new Defender and so far it's disappointed me terribly.
Hope you puma veterans can help.
With thanks,
Nick.
Post #372584 18th Nov 2014 9:25pm
V12vanquish
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
Go back to the dealer and have a drive in another new one and see what it's like.
I too have just recently bought a new one and to be honest I'm some what disappointed with it.
The overall fit and finish and general refinement isn't great, my biggest gripe is probably the gear change, I have only driven a few hundred miles so I'm hoping it will improve with use.
Post #372606 18th Nov 2014 10:26pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Don't hold your breath for that gear change to improve mate. 24k miles and it's still like driving a 2.5 NA Defender!
Post #372607 18th Nov 2014 10:36pm
JustStarting
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Barolo Black
Mine is a MY15 In which I have done 800 miles and I have the pinking noise when under strain
I am meeting two mates at the weekend with new 15's so I am keen to drive theirs and listen for the noise
Is this a known fault or is it genuinely a fault
Funnily enough today as I was driving I did wander why they make that Noise? MY2015 110 Urban Truck Expedition Spec
2005 Td5 TwinCab
1998 110 CSW 300tdi
Post #372609 18th Nov 2014 10:40pm
Mjibex
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Loire Blue
Where do you buy your fuel?
1 garage?
1 brand?
Many brands?
Regards Mark.
Post #372614 18th Nov 2014 10:52pm
ncow84
I've done 1800 miles now. Fuel has almost always comes from one garage, BP, I used their normal diesel for first couple of fills, then ultimate in the hope that it may help, no difference at all, so back on regular diesel.
Sounds to me as if injection timing is slightly out, like an old diesel engine running pre ignition. Very disconcerting for a new, modern, motor. Will be very interested to hear what your friends' sound like.
I'll be very surprised if this genuinely is 'normal' for these engines.
Post #372620 18th Nov 2014 11:11pm
ncow84
Sorry to hear you've not been impressed either. I can sympathise after my repeated visits back to the dealer already.
Gear change on mine has been OK so far, it's precise, if a little notchy, and needs a slow but firm hand, just as my old Landy did. Quick changes from 1st to 2nd just result in crunching and clunking. For a short while 3rd was a little awkward, but freed up after a few miles.
Fit and finish, well, they've never been great for that, at least this one keeps the rain out...
Post #372624 18th Nov 2014 11:23pm
Happyoldgit
I've said it before but if you had chance to drive and compare several new Defenders you will find that there is a tremendous of variation in the way they drive and the sounds they make, this can in part be explained because they are basically an old fashion design assembled in an old fashioned way.
Direct from the factory refined they ain't. Steve.
http://forums.lr4x4.com
Post #372745 19th Nov 2014 2:06pm
ncow84
Not really an acceptable excuse for a thirty grand car. That makes buying a new one something of a lottery... Here in Belfast you're lucky to get a test drive in one, let alone have any others to compare it to.
Post #372897 19th Nov 2014 10:11pm
Caterham
Steve,
you'll be pleased to learn I've sorted my clattering sound. I now leave my brain at home and ensure the music is always turned up load. Very Happy
Nick,
although I've had various problems the biggest / on going problem I have is the sound you refer to. for the life of me I still can't understand it. to me it's an intermittent problem as sometimes its sweet as a nut and I can rev it round to 3.5k without flinching - other times I'm reluctant to use the 'go' pedal.
having replaced various items etc I'm now of the opinion its either the handbrake drum of props......or just me which I could live with if I could just understand why the noise is there, what causes it etc.
feel for you mate and hope its gets sorted to a point where you can live with / enjoy it.
Thumbs Up
Post #372909 19th Nov 2014 10:57pm
Martin
Site Admin
Mine seemed to "pink" a bit in the first few miles after I picked it up (from brand new), it doesn't do it now with 300 miles on it.
Perhaps it needs an injector re-learn - i.e. the thing the dealer has looked blankly at you for Rolling Eyes  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #372987 20th Nov 2014 11:58am
JenDef90
Germany
[quote="Caterham"]Steve,
I have the same story. I am not sure how "pink" noise you hear sounds, but sometimes mine sounds like those old diesels too...and it is a pain to ride. Another time it is smooth and nice to drive. I know it needs sound proofing, but this changing behaviour of the engine is very strange. With other issues (whining noise from the gear or transfer box) I returned it to the service, but they did not find anything.
Tried the dealer's 90 almost same mileage (2000 km on the clock) and used it for a couple of days Shocked that was smooth and nice always Neutral it is really a lottery
now I do not know, will it improve or I should find another service?
Post #373068 20th Nov 2014 5:32pm
Maris Widgeon
England 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
I get to drive a new defender each year at work,and the variation in the way that they drive is quite large.My observations are,
- fuel economy gets better as the mileage rises,
- engine performance improves,
- engine noises vary a lot especially during DPF re-gen,
- during heavy towing there is quite often a pinking sound due to engine running hotter,
- transmission slop varies between trucks regardless of mileage,use,etc,
These are just my observations using a defender for general farm work , and on the whole they have been reliable apart from a few small niggles. The average mileage would be about 15000 a year usually covered in mud and other unpleasantries with different drivers.
Post #373124 20th Nov 2014 8:00pm
ncow84
Funny, what I was hoping I'd get out of this was a load of replies to say 'mines nice quiet and refined', but I seem to have attracted everyone with the same issues as me!
Mines now back at the dealers. They've had it since 8am. I've already had the the obligatory phone call to say 'nothing untoward found yet'. I can't believe the terrible clattering is their idea of OK. I haven't heard a diesel clatter like this in about 20 years!
I'll mention the injector learn to them, again, almost certain they'll give me the 'who do you think you are, we're the pro's, you're just a pleb' look again...
When they give it back (likely still not right), I'll make a video and share it here. If anyone else has clips of theirs I'd be very interested to see/hear those too.
Thanks for the replies folks.
N.
Post #373130 20th Nov 2014 8:24pm
Martin
Site Admin
If you get no joy and you have the option then try another service centre.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #373145 20th Nov 2014 8:54pm
Page 1 of 3 123>
