Home > Maintenance & Modifications > Leaking window seals-can you still buy liquid silicon sealer
Monmouth
Wales 1990 Defender 90 300 Tdi SW Firenze Red
Not strictly a LR question but it may be of relevance to those with aftermarket side windows e.g. camper conversions etc.
Anyway the fixed windows on my transit camper are leaking. I have found cracks in the black window sealant which seams to be some form of Sikaflex adhesive sealant. Removing the windows and reapplying the sealant would be a major undertaking, however I remember using a product called Window Seal which came in a 3-in-1 stylee tin can. It was a liquid sealant which cured once inside the cracks in the window seal. I was wondering if similar products were still available? 1990 Defender 300TDi
Post #370947 10th Nov 2014 11:31pm
shaggydog
Can try this http://www.ebay.co.uk/itm/CAPTAIN-TOLLEYS-...0568235437
Worked for me on sealing my roof Smile
Just make sure you wipe off any excess because it will leave like a PVA glue type varnish mess if you don't wipe it off immediately. Also make sure you do it on a warm dry day or in a workshop where it can creep in and dry, rather than get washed out again. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #370949 10th Nov 2014 11:40pm
dlks151
You could try some of the Techsil RTV product range, its a very viscous product which we use for potting leds for use underwater.
http://www.techsil.co.uk/catalogsearch/adv...mp;search=
Post #370951 10th Nov 2014 11:54pm
gilarion
For anyone trying to cure leaks or in Land Rover terms 'water ingress' this is the stuff to use. I believe it is the same product Land Rover use themselves at least in their water ingress manual it recommends this product.
look here for lionks http://www.defender2.net/forum/topic32417.html
Post #371043 11th Nov 2014 3:44pm
K9F
Captain Tolley's in Saggydog's link is one of the best. If the cracks are large Captain Tolley's first then seal up with Sikaflex 29i afterwards.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #371044 11th Nov 2014 3:48pm
Paddie42
England 2003 Defender 110 Td5 SW Belize Green
K9F..... where do you get Sikaflex 29i from please? or is it the same as Sikaflex 291i?
Thanx in advance
Post #371411 13th Nov 2014 11:43am
K9F
Missed the '1' out sorry. Embarassed Sikaflex 291i best available. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #371442 13th Nov 2014 4:09pm
Paddie42
Thanx... Thumbs Up
At least I'm not going (too) mad Smile
Post #371445 13th Nov 2014 4:23pm
