Home > Tdi > Rear Wiper turns the ignition lights on!
PrivateB
Went out to the Landy this morning to see the rear wiper stuck half way through its sweep - two fuses blown - 2nd and third on top row - replaced them both and now the wiper starts
Only trouble is now the wiper won't switch off and the ignition lights come on with every sweep - with the switch in the off position and the keys not in the ignition.
With the rear wiper motor disconnected and the fuse in place the ignition lights come on
Any help would be gratefully received as I'm no expert in electrics
'97 300TDi Hard Top
Thanks in advance
Post #370354 8th Nov 2014 5:10pm
V12vanquish
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
Sounds like a wiring short, look around the back door etc for a rubbed / nipped wire.
Post #370356 8th Nov 2014 5:16pm
PrivateB
Thanks for the reply
just disconnected all the rear door electrics from behind the rear light and the fault is still there Big Cry
Post #370367 8th Nov 2014 5:54pm
munch90
there is a permament live and a ign live for rear wiper and guess there is a short between these two wires somewhere
sorry unable to tell you where as not a common problem as far I know
what model is it
little pic says 2013
post says 97
just to be sure
Post #370368 8th Nov 2014 5:59pm
V12vanquish
Maybe have a look around the light switch and wiper switch for a wire rubbing the steering column area.
It might end up being difficult to find, but it sure sounds like wires touching some where.
Post #370375 8th Nov 2014 6:20pm
CFB
Water/moisture in the fusebox?
Leaky screen or bulkhead can affect it Andy
Post #370379 8th Nov 2014 6:25pm
PrivateB
Thanks Munch90 - will follow those wires further along in the morning
Little pic is correct and so is the post Smile - it's a new (to me) Hard Top for work - 1997 110 300TDi Hard Top - ExMOD
Thanks again V12vanquish will look there as well.
Strange thing is that although there is current draw (fuse arc's when putting it in) the fuse doesn't blow - not that I have left it in for more than a few seconds
Post #370384 8th Nov 2014 6:33pm
PrivateB
Cheers Andy - doesn't appear to be wet but will check
Post #370385 8th Nov 2014 6:35pm
munch90
what model is it
post says 97
just to be sure
just re read my post and not quite right , there is a ign fed switched feed and a ign fed live
ign fed switched feed , is the one that you switch the wiper on and off with
ign fed live is used to make wiper self park when you switch it off
but still comes down to you got a short somewhere !
if there is a relay for rear wiper , might be worth starting there , pull relay out it might tell you which side short is on , before or after relay
Post #370392 8th Nov 2014 6:49pm
PrivateB
What's making this even stranger is the fact that all this is happening with the ignition off.
Time to start digging deeper - Thanks all
Post #370398 8th Nov 2014 7:20pm
V12vanquish
If there is a live wire touching somewhere it won't matter if the ignition is on or not.
I have my battery tender pig tail lead connected into he fuse box below the drivers seat, there are loads of live feeds in there with the ignition off.
Post #370403 8th Nov 2014 7:42pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
I know this thread has been idle for a while but just another option to be considered if this happens to anyone else.
When my 91 200Tdi did the 'possessed car' think one night, it turned out to be corrosion & shorting in the rear wiring loom where an aftermarket tow socket had been spliced in. Always worth unwrapping this and checking for bad/corroded joints in this area.
Post #406552 11th Mar 2015 12:44pm
