![]() | Home > Tdi > Radiator top plugs |
grumpy old git Member Since: 16 Nov 2013 Location: United Kingdom Posts: 153 ![]() ![]() |
ERR4686B fitted ours just fine, it's the same part number as the plastic except for the b brass. One was a little tight but didn't cross or strip the threads. I'm sure there is only one size.
Aimbones Member Since: 16 Jan 2015 Location: Erith Kent Posts: 2 ![]() ![]() |
I fitted radiator bleed plugs. 1/2" bsp makes bleeding a doddle.
X Engineering make some anodised aluminium ones - their website might help confirm if there are more than one size/thread?
I had a set of the X Eng ones - they are exactly the same thread
![]() EDIT - From Foundry 4x4 site "A good looking and functional replacement for the nasty plastic caps supplied with modern vehicles. The X-Cap can be removed with any multi-tool: most spanners (edge on): 27mm wheel wrenches and if you have nothing else: even a stick will do. It will fit the vast majority of Land Rover vehicles plus others with a 3/8 BSP thread. It is designed to fit in the top of the radiator on PRE Td5 engines. The Td5 has a plastic bleed plug in one of the hoses which is a different size. It will also fit the Axle Filler plug on Discovery 2 and in to the thermostat housing on 300Tdi engines." |
