Home > Tdi > Radiator top plugs
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
Radiator top plugs
I have just tried fitting a brass radiator plug but it doesn't fit. Are there two different sizes, the plastic one fell apart when I removed it so I can't compare thread sizes. 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #370149 7th Nov 2014 4:09pm
grumpy old git
ERR4686B fitted ours just fine, it's the same part number as the plastic except for the b brass. One was a little tight but didn't cross or strip the threads. I'm sure there is only one size.
Post #370202 7th Nov 2014 7:16pm
Aimbones
I fitted radiator bleed plugs. 1/2" bsp makes bleeding a doddle.
Post #409499 21st Mar 2015 10:58am
X Engineering make some anodised aluminium ones - their website might help confirm if there are more than one size/thread?
Post #409834 22nd Mar 2015 10:39am
grumpy old git
I had a set of the X Eng ones - they are exactly the same thread Thumbs Up
EDIT - From Foundry 4x4 site
"A good looking and functional replacement for the nasty plastic caps supplied with modern vehicles. The X-Cap can be removed with any multi-tool: most spanners (edge on): 27mm wheel wrenches and if you have nothing else: even a stick will do.
It will fit the vast majority of Land Rover vehicles plus others with a 3/8 BSP thread.
It is designed to fit in the top of the radiator on PRE Td5 engines. The Td5 has a plastic bleed plug in one of the hoses which is a different size. It will also fit the Axle Filler plug on Discovery 2 and in to the thermostat housing on 300Tdi engines."
Post #409854 22nd Mar 2015 11:37am
