![]() | Home > In Car Electronics > Radio reception issue |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20691 ![]() ![]() |
You can get noise suppression filters, sometimes it's caused by cable runs following each other especially power cables rather than crossing at right angles.
It's particulary true of power cables of high consumption. I'd imagine there is something on the market to sort out the issue. The HU Earth could do with checking too. Premium HU's have their own USB connections that can allow functions to be accessed and charge at the same time. Trouble is that tech changes so fast HU's have a lag to keep up. |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1314 ![]() ![]() ![]() |
Mk 1 filter ready for testing over the weekend
![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5920 ![]() ![]() ![]() |
I get interference when using my dual blue sea USB adapter with various USB leads. My blue sea is mounted in the Mudstuff dash pod. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Macpaul Member Since: 26 Mar 2013 Location: SW Surrey Posts: 439 ![]() ![]() ![]() |
Funny old world; my Blue Sea USB twin socket mounted close to the radio on the side of my tdci console, makes no difference at all to the very good radio reception. Powered from the lighter socket too I think. 2003 Td5 110 Hardtop
Now a 2013 110 USW too. |
Filter seems to have done the trick. I have three USB power lines:
1) Dual USB socket for charging things - this has built in step down voltage 2) USB cable for Satnav charging - this has the internet bought step down box 3) USB cable for dashcam - this cable came with its own step-down voltage box Filter is on the last item - seems to work as I have great radio reception now Will have to check if the other devices also need a filter but all seems okay for now |
