Home > Puma (Tdci) > Gearbox (?) whine above 100 km/h
JenDef90
Germany
I know whining problems has been discussed before, however not on a new / low mileage Pumas.
Mine has 2000 km on the clock , and on a longer trips., after approx 30 km distance , at speeds above 100 km h it starts a high frequency very annoying whine..it comes from underneath of the the middle section between the front seats...gear box transfer box ? Is it normal? Maybe an oil change would help?
I guess NK produced bell house noise killer products are the sign of a general issue...
thanks for any ideas
Post #367418 27th Oct 2014 6:19am
LR90XS2011
not noticed anything like this in mine, just in case check to see if the hand brake drum is very hot after a run, it could be dragging , if not I would suggest you take a ride in another one to compare (perhaps the dealer has a demo) and then if not happy get them to fix it DEFENDER 90 TDCI XS,
Post #367419 27th Oct 2014 6:26am
JenDef90
Germany
thanks for the advice, I will check the drum first. I noticed extensive heat from the underneath too, but my guess was that it is coming from the exhaust pipes so did not investigate further.
In fact I had a chance to drive a demo for a longer trip, when mine was in for the anticorrosion treatment - it was a huge difference Shocked the demo was smooth and nice, no whine at all and it was also a very low mileage Def90.
I thought the difference was mainly because mine is a basic model- rubber carpets only in the front, bare metal arches in the back + noisy MT tires on. So, now I changed to ATs on alloys, put a premium rear carpet set in which improved the comfort except the whine Big Cry
any experience on this ??? http://www.nkgroup.co.uk/product/land-rove...g-blanket/
Post #367432 27th Oct 2014 8:53am
It is not unknown at all for the transfer box to whine, something which is common on high-mileage vehicles as the intermediate shaft bearings (in particular) wear. It shouldn't of course be happening on yours, but that doesn't mean that it isn't.
It is also normal for the transfer box to get very hot, especially during a long high speed run.
I would be inclined to drain the t-box oil and inspect both the volume and condition of what comes out, looking for either over- or under-filling, and/or signs of bearing damage. I'm not saying there'll be any, but I'd want to rule it out.
Post #367522 27th Oct 2014 2:58pm
Juhulia
2012 Defender 110 Puma 2.2 SW Keswick Green
Could also be the turbo hose issue ...
Post #367626 27th Oct 2014 8:52pm
MK
My 07 had the whine in 6th since new. A new gearbox solved the problem. Puma 110" SW
Post #367715 28th Oct 2014 9:34am
Happyoldgit
Transmissions are variable straight from the factory, some quiet, some less so. Gearboxes and axles can all vary in how much racket they produce, if you had the chance to try several new Defenders I bet you'd find each one was different. Steve.
http://forums.lr4x4.com
Post #367788 28th Oct 2014 4:17pm
JenDef90
Germany
many thanks for the infos, now it is scheduled to be examined by the dealer next week. will update as soon there will be any news.
Post #368500 31st Oct 2014 4:17pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Good luck getting to the bottom of it,transmission noises are some of the most irritating ones as they can drone more than a politician. My car is back in the garage in 2 weeks to have the diff changed again as the last one they put in was noisier and had more backlash than the one it replaced!! 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #368508 31st Oct 2014 4:44pm
Mongolia
France
[quote="MK"][i]My 07 had the whine in 6th since new. A new gearbox solved the problem.[/i][/quote]
Mine also 07 with 180000 km on the clock with a whine in 6th when running between 110 km/h and 130 km/h.
Can you help me, any idea: transfer case? gearbox? or rear axlle?
Post #371661 14th Nov 2014 6:43pm
MK
it is easy to tell if comes from the back or center. If you spot it from the center, then try it at such speed in 5th. If it goes away then you could blame the gearbox, otherwise it could be the transfer case. Puma 110" SW
Post #371761 15th Nov 2014 12:08pm
