Home > Land Rover Customer Relations > LandRover Assistance (or the lack of)
Page 2 of 4 <1234>
uncas
Why not try a battery yourself? Ok the vehicle maybe under warranty but its YOU that is being inconvenienced by the failure to start etc. Can you borrow a battery from someone local just to test the vehicle? and prove or discount it. I'm afraid that I have little patience with some dealers and garages that can only follow written procedures being a rough rsed plant fitter I have to get stuck in
Uncas
Post #372439 18th Nov 2014 10:26am
CRC@LandRover
Verified Account
Verified Account
Hi borderterrier
Thanks for your posts.
As previously advised, should you require me to assist you and speak with your retailer, I will be happy to do so if you would like to PM me with your details.
Regards
Ryan
Post #372484 18th Nov 2014 2:29pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
So the dealer has found a drain on the battery. It amounts to 262 milliamperes. Is that enough to discharge a battery enough over a few days to stop it cranking over the engine?
Post #372558 18th Nov 2014 8:33pm
K9F
That is quite a resistive value you have, nearly 46 ohms draining your battery. If my calculations are correct and you have a 65 ampere hour battery it would take approximately 10 days to completely flatten it. How long it would take before it wouldn't crank or you have no dash lights when ignition is switched on I have absolutely no idea but it would be significantly less than the 10 days mentioned previously so 'a few days' I would say yes! Sorry I cannot be more precise. Connecting an ammeter in series or using a clamp meter on your battery feed whilst pulling your fuses/relays may give you a good pointer where the drain is coming from.
Good luck. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #372566 18th Nov 2014 8:51pm
borderterrier
Of interest are my interior led festoon bulbs which appear to glow even when they are supposed to be off.
Post #372569 18th Nov 2014 8:55pm
munch90
No they shouldn't glow !
Maybe lr were right in the beginning Rolling with laughter
Post #372644 19th Nov 2014 6:54am
borderterrier
I know I thougbt that. Maybe some humble pie is in order if it works out they have been the cause! My fault, buy cheap, buy twice! Rolling Eyes
Post #372648 19th Nov 2014 7:25am
SailingTom
So it was down to some dodgy LED interior bulbs in the end then? Defender puma dormobile camper
Post #372661 19th Nov 2014 8:40am
K9F
Are these the lights switched from the door switches and the on/off courtesy switch in the headlining? If so they shouldn't be getting any supply and you may have a short circuit in one of them perhaps? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #372665 19th Nov 2014 9:03am
borderterrier
Yes they were fitted to replace the OE festoon bulbs. I have removed them both and I will keep an eye on it for a few days to see what happens.
Post #372676 19th Nov 2014 9:32am
uncas
As K9F says they (the LEds) can't operate unless they are getting some power i.e. door switch shorting etc has any one checked across the bulb connections with a meter to see if there is a short?
Uncas
Post #372798 19th Nov 2014 4:54pm
borderterrier
I put a tester across the terminals of the interior lights and there is a current. Oddly there is non when in the off position. There is current in the on position as you would expect, but there is also current when the switch is in the door position. Ideas?
Post #372846 19th Nov 2014 7:48pm
munch90
Sorry to maybe state the obvious , but when you tested the lights for getting current did you have the door shut and wait for light delay before checking for current when switch in door position
also how much current if it enough to only light a led dim then it could be water in a relay , switch , control box , etc etc
I take it it not enough to light a standard bulb
Post #372850 19th Nov 2014 7:57pm
borderterrier
Yes I waited till they had gone off, but good point. Not sure of the voltage, I was only using a basic go, no go tester. I will check to see if there is enough to power a standard festoon bulb.
Post #372851 19th Nov 2014 8:04pm
munch90
Not the same problem but just as a example , my rear led worklight can be on with reverse lights , off , or on alone with a small flashing red led indicator inside .
moved defender parked and noticed red led flashing oddly , ign off, out of reverse etc went round back worklight flashing dimly , had a quick lookat wiring behind speaker panel and water had run down a wire in to the relay ( which was mount terminals up ) and was shorting enough through the water to make the leds light dimly , the water would not have passed enough current for a normal bulb to light up
changed relay moved it all fine
sometimes leds working on such low current is not such a good thing
Post #372860 19th Nov 2014 8:40pm
Page 2 of 4 <1234>
