Home > Puma (Tdci) > Grease
Grease
Hello all again, What grease / lube do you all use for your door hinges ect? When I got my Puma from dealers there was a white grease there however I don't know what it's called. Thanks
Post #31765 8th May 2010 7:13pm
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Probably a Lithium grease. At least that's what I use. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #31767 8th May 2010 8:52pm
spudfan
Ireland
My service sheet lists XCONS 6075 COPPER GREASE XPART.So that was used to grease what needed greasing. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #31775 8th May 2010 11:57pm
spudfan
Ireland
I also found Genuine Parts Service Lube STC 50545 left in the car after the first service. This sprays white stuff and is made by Loctite. The tinsays-lubricates,frees,displaces moisture. Maybe this is what the dealer used on yours. 1982 88" 2.25 diesel
Post #31782 9th May 2010 9:06am
dgardel
Italy
White grease normally is teflon based grease...... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #31807 9th May 2010 8:06pm
MK
Just the opportunity to say: who cares about any grease if LR can not even fit/design a proper transmission components Evil or Very Mad Puma 110" SW
Post #31809 9th May 2010 8:20pm
