Home > Puma (Tdci) > Grease |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 |
8th May 2010 8:52pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4662 |
My service sheet lists XCONS 6075 COPPER GREASE XPART.So that was used to grease what needed greasing. 1982 88" 2.25 diesel
8th May 2010 11:57pm |
I also found Genuine Parts Service Lube STC 50545 left in the car after the first service. This sprays white stuff and is made by Loctite. The tinsays-lubricates,frees,displaces moisture. Maybe this is what the dealer used on yours. 1982 88" 2.25 diesel
9th May 2010 9:06am |
White grease normally is teflon based grease...... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
9th May 2010 8:06pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2415 |
Just the opportunity to say: who cares about any grease if LR can not even fit/design a proper transmission components Puma 110" SW
9th May 2010 8:20pm |
