![]() | Home > Td5 > Rear light protectors |
I have COR4 guards and they fit with my carrier. Any pics of your carrier they may help.
![]() Click image to enlarge ![]() Treat every day as if it is your last....one day you will be right!! |
Tank Member Since: 25 Jul 2014 Location: Fife Posts: 431 ![]() ![]() ![]() |
Cheers K9F
It's dark ! Can't take a photo ! Yours look spot on for me ! Cheers Duncan |
takoon Member Since: 16 Oct 2013 Location: central Posts: 48 ![]() ![]() |
What make is Your wheelcarrier K9F? -99 Td5 90 CSW
-09 Jaguar xk4,2 Portfolio |
Safari Equipment Single Pivot.
http://www.defender2.net/forum/topic18175....swing+away If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5884 ![]() ![]() ![]() |
@K9F I'm not sure if electrical tape and plastic bags are a good enough to support the carrier..... 1999 Defender TD5 110
It'll do a trip!
Aha, looks great and neat
![]() -09 Jaguar xk4,2 Portfolio |
Hijacked post ! It's supposed to be about light protectors
Swing away follows the door. The rear lightguards are from LRS Offroad...Had to wait a while for them all to come in but worth the wait...
http://www.lrsshop.co.uk/content/cor4-rear-light-guards Here's a picture of the sliding rear door plate.... ![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
I asked a friend to cut mine and re-weld them and he did a great job. So all is good thanks
![]() Duncan |
ppad Member Since: 16 Nov 2012 Location: now, UK S Coast Posts: 223 ![]() ![]() ![]() |
Can anyone point me to the definitive thread on wheel carriers
![]() Looking at: opens with door / or not; materials, mounting points etc. My TD5 90 has normal ish 235/85 R16 and I really want to put a simple (can be independent of door) non rusting (I'm keeping it) carrier .... Ta. Sold the much modified 110 2.8, in Oz Brought the 90 home from Switzerland ... |
The nakatenenga one is the best in my opinion, look in 4x4 overlander site sponsor section.
