Home > Technical > Brake problem....
delab
United Kingdom 1996 Defender 110 300 Tdi CSW Epsom Green
Brake problem....
From day one of owning my 110 300 tdi it suffered from brake pads rattling in the callipers. That issue still hasn't been resolves however one suggestion at the time was to change the front pads and callipers.
Having had the pads and callipers changed, and brake fluid whilst I was at it, I immediately noticed poor braking which is still present some three weeks later.
The problem is upon first pressing the brake pedal braking is soft and poor. Release the brake and brake again then the braking is excellent, just as I remembered it.
I initially thought the system had not been bled correctly so it went back to the garage who bled the entire system again but still the problem exists.
Any ideas folks? The original callipers were AP Lockhead and the replacements were Bearmach. Could it just be crappy callipers or am I missing something here?
Post #362057 3rd Oct 2014 11:27pm
dgardel
Italy
brake pump? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #362100 4th Oct 2014 8:14am
munch90
master or air in the system ?
Post #362109 4th Oct 2014 8:48am
shaggydog
Check your vacuum hoses and vacuum pump and servo.
If everything else is fine and there are no leakages and there is no air in the system might be one of the above.
Post #362121 4th Oct 2014 10:29am
jst
wheel bearings? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #362195 4th Oct 2014 6:41pm
As JST says, or ABS block.
Post #362196 4th Oct 2014 6:45pm
munch90
if new discs were fitted then wheel bearing could be set up to loose allowing disc to push pads away from it , first push of pedal puts pistons back second push gives good pedal and braking effect
Post #362201 4th Oct 2014 7:04pm
dorsetsmith
new discs and pads will file spongy tell they bed in Exclamation
Post #362204 4th Oct 2014 7:12pm
delab
Thanks for suggestions to date. I should have said the discs weren't changed. THE LR has just gone throughout the MOT fine so it shouldn't be the bearings although I will check as that suggestion makes sense whereby the first application of brake is spongy then the second application immediately afterwards is really good.
What I can't work out is prior to calliper change the braking was good but now with new calipers it's as I've described...
Post #362293 5th Oct 2014 11:17am
g-mack
to rule out vacuum probs, put foot on brake hard, start engine, you should feel the pedal drop substantially! if it doesn't move you definitely have vac problems. it may move a little, you could still have vac probs! My 109 thread
my youtube channel
Post #362297 5th Oct 2014 12:05pm
delab
OK... i've tested the vacuum pump as suggested by g-mack. Pumped the brake several times, start the engine and there's no give whatsoever. So that means the vacuum pump has gone? Do I need to check anything else related to the vacuum pump?
Post #362330 5th Oct 2014 3:00pm
munch90
pipe work from pump to servo ?
not unknown for the servo to crack , have a real good look round the front of it where the master bolts on just out a bit from the flange of the master cyl
Post #362334 5th Oct 2014 3:05pm
delab
Thanks for that Munch90... I'll check/ replace that too...
Post #362564 6th Oct 2014 10:06am
delab
I removed the vacuum pump pipe into the servo and there's loads of suction. The garage inserted some fandangled smoke machine into the servo via the empty hold and state it's not losing compression. Still puzzled then other than maybe the bearings... even though it passed the MOT three weeks ago when I first discovered the 'fault'
Post #362655 6th Oct 2014 4:43pm
munch90
still could be air in the system , just because you cant get any out doesn't mean its not in there
a lot of times the master is blamed , someone thinks its a master problem , changes master , bleeds system all ok , but its the extra bleed that done it not replacing the master
when the calipers were done was the system left to drain out , or sealed , change calipers , then bleed to change fluid
I would still have a good look at the servo ,
Post #362677 6th Oct 2014 5:47pm
