![]() | Home > In Car Electronics > Tweeter Replacements |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20619 ![]() ![]() |
1" size is standard. I have Kicker tweeters but they are expensive and not available readily in the UK. There are many alternatives on the maket but go for quality. I.e. Known brands.
Raddy Member Since: 20 Aug 2013 Location: St. Sampsons Posts: 55 ![]() ![]() ![]() |
Do most just slot in or do you need to faff about and remove the existing casing for them to fit snug.
Im fine when it comes to bashing things with a hammer or painting something but not so hot on fiddly, delicate things like speakers! ![]() |
Original tweeters just push out leaving a 1" hole. Fitting new ones depends on the manufatcurer.
If you want any further help with anything your welcome to drop me a PM. ![]() |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 ![]() |
A 40mm hole saw was a perfect size for my focal tweeters,you only need to cut the dashboard foam, then a small hole through the metal for the wire. Pov.spec,ftw. 2006, 110,TD5.
