Home > In Car Electronics > Tweeter Replacements
Raddy
Guernsey 2007 Defender 90 Puma 2.4 CSW Rimini Red
Replaced all the speakers bar the tweeters in my puma, now they just don't cut it.
I have no idea where to start in regards to tweeters.
any recommendations that aren't going to cost the earth and advice on size? Thanks!
Post #359247 21st Sep 2014 4:09pm
1" size is standard. I have Kicker tweeters but they are expensive and not available readily in the UK. There are many alternatives on the maket but go for quality. I.e. Known brands.
Post #359249 21st Sep 2014 4:27pm
Raddy
Do most just slot in or do you need to faff about and remove the existing casing for them to fit snug.
Im fine when it comes to bashing things with a hammer or painting something but not so hot on fiddly, delicate things like speakers! Shocked
Post #359251 21st Sep 2014 4:33pm
Original tweeters just push out leaving a 1" hole. Fitting new ones depends on the manufatcurer.
If you want any further help with anything your welcome to drop me a PM. Thumbs Up
Post #359276 21st Sep 2014 6:53pm
jimbob7
A 40mm hole saw was a perfect size for my focal tweeters,you only need to cut the dashboard foam, then a small hole through the metal for the wire. Pov.spec,ftw. 2006, 110,TD5.
Post #359990 24th Sep 2014 7:29pm
