Home > Td5 > abs and warning light flickering when under throttle
silky16v
England 2001 Defender 90 Td5 X-Tech LE Blenheim Silver
Hi strange one this, had some problems originally with the 3 lights (warning, abs ,tc)
It is a 2001 TD5 Defender 90 X-Tech
fixed those by aligning the sensors, now when i drive all the light go out (handbrake doesn't seems to work)
but as you apply power in any gear the abs light flickers and sometime the warning light, but as soon as you come off the power or coast with very very light throttle they go out.
have had it code reader (garage spec 2013 snap-on) and nothing is showing as faultly
then the other day i though while driving (slowly though) i'll just slightly pull the handbrake lever up just until it starts to bite and hey presto the flicking abs lights goes out
the previous owner had fitted a new handbrake cable and there seems to be a lot of travel in the handbrake lever about 30deg of movement, i've checked the switch and that looks all ok
i've done the usual checks for earth cables by the ecu's and checked for any signs of damp and oil in both looms
i've ran a new earth wire 5mm thick from ecu compartment to the bulk head and this has made no difference
the TC & ABS work fine (tested these off road on some gravel at a local MX track) checked brake fluid levels and float has full movement
is there a switch on the gearbox or sensor that might need cleaning replaced and if so where about's is it?
would like to try and get to bottom of the flicking before winter and fix the handbrake light coming on and off
Thanks for any help
Post #358206 16th Sep 2014 1:23pm
K9F
Chafed cable under the vehicle. Mine initially only manifested itsel in damp conditions but in the end got worse so I could find it. Intermittant faults are always the worse to find. Took a while but on page 3 I finally located it.
http://www.defender2.net/forum/topic2394.html?highlight=inline If you go through life with your head in the sand....all people will see is an ar5e!!
Post #358212 16th Sep 2014 1:51pm
silky16v
yeah i seen that thread the other day and have checked and the cabling and all looks ok, will have another dig around.
it just seems weird its connected to the acceleration and then backing off, so thats why i though gearbox sensor
Post #358216 16th Sep 2014 2:27pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
Could bearing play cause this? Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #358311 16th Sep 2014 9:03pm
Ken B
I had same problem and spent months looking, eventually noticed despite all earths being good that there was spiking voltage to ECU !
Earths on battery boxes on both drivers and passengers side of my 90 seemed intermittently faulty, ran a new earth from the battery and through the chassis to both sides.
All sorts of issues sorted ! Defender 90 TD5 County -
You need only two tools in life: WD-40 and duct tape.
If it doesnt move and it should: WD-40.
If it moves and shouldnt: duct tape it.
Post #359136 20th Sep 2014 8:41pm
bear100
Loose connection on the abs socket 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #359137 20th Sep 2014 8:46pm
silky16v
fixed
just an update fixed it finally today
first off replacement handbrake light switch from LR, that sorted the handbrake light working but the lights continued to flicker
i then remove the whole handbrake assembly and touched the wire to HB switch straight to the chassis, red light came on wiggled wire no flickering
so suspected the the handbrake assembly isn't earthing correctly, so rubbed off some paint on the body beneath the HB and re-fitted went up the road and wiggled handbrake no more flickering
Problem solved
oh also adjusted HB to 3 clicks now instead of 5 Thumbs Up
Post #361772 2nd Oct 2014 7:33pm
NickMc
Try cleaning the White earth header block (plug with loads of wires going into it)beside the pedal boxes and steering column on the bulkhead (left hand side engine bay side near the expansion tank) earths through the stud its fitted to. This controls the instrument warning light earths.
Post #361814 2nd Oct 2014 9:16pm
