Home > In Car Electronics > New XS Defender Audio System and amp upgrade |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
My 2014 XS came with Bluetooth and mic without the stereo 'upgrade'
22nd Oct 2014 7:20pm |
My 2013 XS came with Bluetooth and mic without the stereo 'upgrade'
23rd Oct 2014 2:02pm |
2 GOS Member Since: 03 Aug 2014 Location: Hertfordshire Posts: 66 |
Can you tell me where land rover put the amp and remote for this sub? Pictures appreciated. Thanks.
I realise they could go under a seat but....where do LR put them? Thanks in advance. |
26th Oct 2014 4:51pm |
It's an active sub so the amp is inbuilt but as for the remote I don't know as I don't have one
26th Oct 2014 4:56pm |
All the pictures show a separate amp.
See photo |
26th Oct 2014 5:01pm |
I thought the factory fitted ones were active subs
26th Oct 2014 5:16pm |
I believe the amplifier is built into the same housing as the speaker as I've never found a seperate amp and the controls are through the stereo.
26th Oct 2014 5:20pm |
Vanderbult Member Since: 28 Oct 2015 Location: amsterdam Posts: 20 |
Hey Browjam, could you tell me which Alpine speakers and amp you installed? |
28th Oct 2015 2:52pm |
saltydog Member Since: 13 Mar 2012 Location: Aberdeenshire Posts: 91 |
I have the standard upgraded Apline head unit.
I paired it up with the following: Upgraded rear speaker with Mud Speker rings and Focal PC130 Speakers Fitted the following sub woofer onto the rear of the cubby. It has a control unit to alter the amount of base, I located this just inside the cubby box. http://www.alpine-europe.com/p/Products/po...5/swe-1200 Sound is fantastic actually, I plug in my iphone to the USB and also via bluetooth and the sound A1. Probably 100's of other done exactly the same as I have already so nothing new but in short the standard head unit with two simple upgrades makes the world of difference in my opinion. LR Defender 110 XS Utility Wagon LR Discovery 2.0 Sport HSE LR Discovery 4 Landmark |
28th Oct 2015 4:52pm |
Vmesch Member Since: 06 Dec 2014 Location: Antwerp - Lier Posts: 47 |
I'm also planning the active sub upgrade... Where did you take the 12V supply from? Could you send any details or pictures? puma 2.2 MY2013
[:O]===[O:] |
14th Nov 2015 9:47am |
