Home > Maintenance & Modifications > Cubby boxes |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3708 |
I fitted one of these. Its designed for the earlier models so it has to be mounted further back on the 07my (because of the gear leavers). Basically drill new holes and fit as normal. They may have re-designed them to fit the 07my by now.
http://www.safari-equip.co.uk/index.php?page=61 |
13th May 2008 8:11am |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
Not yet but I'm thinking of fitting a Mobile Storage Systems box which looks very similar to Andrew's link.
13th May 2008 9:14am |
Trevor Wright Member Since: 11 May 2008 Location: Essex Posts: 87 |
If your 90 XS is a Puma then the Mobile Storage Systems (MSS) cubby (the best made and most expensive I believe), cannot have the cup holders on the front due to the position of the gear stick. If you want the cup holders then you'll have to drill two new holes so it can be positioned slightly further back. You'll need to decide exactly what configuration you want from them and then get a quote. Fitting is a two-person job I understand as a bar is fitted underneath between the seat boxes. Maybe one day LR will produce a Cubby with a lock on it, and made from steel instead of chipboard or whatever. Hope this is of some assistance. Trevor Wright '08 90 TDCi/TD4 XS SW |
13th May 2008 3:53pm |
There is no way you will fit it and be able to fit the cup holders, well not without it taking up space in the rear. As far as fitting is concerned I used the existing 4 rive-nuts that the original wooden cubby box used. So its a one person fit. I will take some pictures.
13th May 2008 5:27pm |
Here you go
13th May 2008 5:51pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6622 |
I've got this one in my 90, albeit with a retrimmed lid to match the seats:
It's got a 3 point security lock internally, with a lip all the way round the top so it can't be crowbarred open. It's more basic (less fussy ) than the MSS one, ideal if you don't need a CB or radio fitment. |
13th May 2008 8:08pm |
Icelandy Member Since: 27 Feb 2008 Location: Hathern Posts: 54 |
Can anyone tell me how to remove the orginal cubby in a puma? Is it just the 2 bolts that are accessed under the cupholders? If so, is it a special screwdriver i need?
Thanks If a job is worth doing.... Its worth doing well.... So get someone who knows what they are doing! |
3rd Jun 2008 6:39pm |
Verdone Member Since: 30 Apr 2008 Location: Gent Posts: 67 |
Yeah and they are torck screws so u need a torcksscrewdriver ... Im from belgium and thats how we call them |
3rd Jun 2008 7:23pm |
Andrew, what are all those switched on the lower part of your dash?? I assume you have added those? If a job is worth doing....
3rd Jun 2008 8:47pm |
Lights mate 2 pairs of roof spots, left and right rack mounted work lights, rear mounted work light, front warning lights and rear warning lights. I think thats it |
5th Jun 2008 4:09pm |
