Home > Maintenance & Modifications > Headlining removal - with sunroof |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
I have the pop and clunk variety on my 110 so it may well be different for you but my removal was as follows and fairly simple.
Undo the visors and mirror if fitted,then gently feel your fingers under the plastic strip that bridges the gap between the sun roof and the headlining and gently work it down. It is attached with tiny fir trees held within the plastic so be careful as they are a bit delicate. Under that there are some small bits of steel which grip or form a shelf for the headlining to fit onto, these are held in with a single screw so just undo and put somewhere safe. Then undo the remaining fir trees and lift (fight) out. |
9th Sep 2014 12:11pm |
