Home > Maintenance & Modifications > Help with wiring please.
Cibit
I am a tad confused so thought some clever people might ride to my rescue.
Ok I have been wiring up my lights and now I come to the wiring to switches and relays.
This is the relay diragram I found online
http://www.ado13.com/techs/relay.htm
Questions:
If my lights are wired to the battery via a relay do I need a power from ignition switch lead?
Do I really need to earth the relay and should the switch be earthed
The lights are all earthed on a loop direct to - terminal on the battery
All help appreciated Thumbs Up 59 2.4 110 XS Utility
55 TD5 110 CSW Special Vehicle
Post #30750 26th Apr 2010 6:42pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Still got a bruise on me heed from that melon.............. Censored  Original Member Pie n Pea Club.
110 HCPU Tipper
Post #30751 26th Apr 2010 6:52pm
Cibit
Still waiting me invite for tea. I mean I brought the veg Shocked I will bring a chicken next time see if you can take a hint Thumbs Up Duck
And I still have a sore shoulder from holding up the ute at the tipping point last week Razz 59 2.4 110 XS Utility
Post #30752 26th Apr 2010 6:58pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
yes earth everything i have a permanent live feed to mine but ignition live feed will do
cheers steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #30753 26th Apr 2010 7:06pm
Cibit
Ok more concise question.
Do I need to have power to both the switch and the relay?
But thanks for the more helpful reply Steve Whistle 59 2.4 110 XS Utility
Post #30754 26th Apr 2010 7:15pm
big steve
i have 8 light with 3 switches we run a loom from under drivers seat to the switches in dash basically a power cable that split to the 3 switches
then the rest of the wiring went from dash to battery side i have 3 relays behind the seat which have mains power straight from battery which are individuel to each relay which are also fused
hope this helps cheers steve 2015 2.2 tdci hardtop xs
Post #30755 26th Apr 2010 7:33pm
Cibit
This is how I am set up at the moment
Lights to relay.
Relay to earth.
Battery to relay.
Relay to switch.
The lights are earthed to the battery.
What now confuses me is what connections need to be made on the switch side?
Do I need to supply power to the switch even though the relay is supplied power?
I thought adding 2 power leads to one component would lead to a flash and a bang? Embarassed 59 2.4 110 XS Utility
Post #30758 26th Apr 2010 8:06pm
K9F
Cibit,
Wiring the lights purely depends on how you want them to switch on and when! Off your main beam and when the ignition on is best!
This is how I wired mine in laymans terms, they will only come on with main beam but can be isolated with a separate switch!
Positive supply direct from battery to relay circuit supply in via an inline fuse (30). Relay circuit supply out to lights (87). Earth from lights to earth vehicle chassis! Tap off from headlamp main beam supply to switch input (no fuse needed in this instance)! Switch output to relay coil (86)! Relay earth to vehicle chassis (85)!
Dependant on what type of switch you have you may need to add extra cable from relay output back to switch if the switch is an illuminated type when on!
Hope this helps! This configuration will allow your lights to come on when main beam is selected AND the switch is selected on! Deactivation of either will switch lights off! Hope this helps!
Now I'm back in at work I have found this off Google schmoogle....
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #30762 26th Apr 2010 9:28pm
Coolcamper55
Scotland 2007 Defender 110 Puma 2.4 XS CSW Santorini Black
If you consider that a relay has 4(sometimes5) terminals. Two of them operate the relay coil which when 12 volts is applied move the contacts to make the circuit to carry 12 volts to the load, light, fan, whatever via the other two contacts.
So when you want to engergise the relay, you throw the switch, the switch has a connection to a 12 volt supply and then to the relay. It also has a third connector which goes to earth and that is to allow the neon to light when you throw the switch.
There is no need for a earth on the relay, the earth can be at the light or fan i.e. the load end save running lots of cable
The reason for using relays is that if you consider say a light bar drawing 20 Amps you do not want that sort of current running thro the dash board. The current flowing via the switch is about 1 amp which means the wire guage is very much reduced and you do not have lots of power running around the back of the dash.
Hope this helps,
Tommy Tommy
110 XS TDCi
Post #30778 27th Apr 2010 6:00am
alantd
Out of interest, why do you tend to put the switch on the earth and not the live? I've seen this done before and was wondering whether it's a specific vehicle thing or general electrician practice Question One that started out as a 2.4 TDCi 110 XS
Post #30793 27th Apr 2010 9:31am
K9F
' Best trade practice.' Safer to switch an earth with little or no potential than a live feed with full circuit voltage! Less chance of arcing and sparking! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #30798 27th Apr 2010 10:03am
TallPaul
Its also easier to "bodge" in a remote location or emergency. For example the IBS split charge I have in the Disco switches the earth, so if your whizzy voltage monitoring control panel dies, you just chop the control cable to the relay that links the battery and earth it if your stuck somewhere and need to dual batteries.
If it was switched live, you would need a live feed, fuse, etc. Disco 3 gone but the memory of the bills remain...
XS 110 Utility maybe one day..... (did they fix the quality yet?)
Post #30801 27th Apr 2010 10:44am
Cibit
Thanks for the replies Thumbs Up
I have earthed both switches and relays and the switches have constant live. I have the relay power feed via the winch loom cut off switch so that needs to be on to power the relay and lights.
No burning smells yet and the instalation is reasonably tidy so fingers crossed Wink 59 2.4 110 XS Utility
Post #31071 29th Apr 2010 5:23pm
