Home > Maintenance & Modifications > Nakatanenga Rear Wheel Carrier Bracket |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5792 |
I'm not sure we need items from "your far end", but you know best
Andy |
29th Aug 2014 10:28pm |
Andy, you will get a good slapping if you are not very careful
Brendan |
29th Aug 2014 10:51pm |
30th Aug 2014 8:15am |
Yannis Member Since: 02 Feb 2015 Location: Oxfordshire / Milan Posts: 408 |
Sorry to bring this back up, but did anyone ever find a wheel carrier with a built in bumperette and a matching one for the other side or a wheel carrier compatible with existing bumperetes?
20th Jan 2017 9:25am |
Grey110 Member Since: 20 Jun 2012 Location: Delft Posts: 35 |
Hi Yannis,
I have an Ex-Tec rear wheel carrier which fits with bumperettes. Only drawback is that it is expensive. See http://shop.ex-tec.de/product_info.php?products_id=6 Martin Martin Previous 2003 Defender 110 Hardtop TD5 2004 Defender 110 Station Wagon TD5 - Libyan Sand 2005 Discovery 3 - V8 - Black |
20th Jan 2017 9:39am |
I do not know of a swing away wheel carrier which has built in rear bumperettes/corner protectors. The best swingaway wheel carrier I have come across is the Nakatanenga stainless steel wheel carier. They have rear corner protectors which fit with thir wheelcarrier on 110's and 90's without mudflaps. Be aware that many cheap rear bumperettes will not work without modifications with most swingaway wheel carriers. Brendan |
20th Jan 2017 10:08am |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 |
That is some Hinge Bracket No wonder its that price. Quite interesting that it takes a lot of the deformation out of the equation from the rear tub. |
20th Jan 2017 2:43pm |
