![]() | Home > Maintenance & Modifications > Nakatanenga Rear Wheel Carrier Bracket |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5799 ![]() ![]() |
I'm not sure we need items from "your far end", but you know best
![]() ![]() Andy |
Andy, you will get a good slapping if you are not very careful
![]() Brendan |
Yannis Member Since: 02 Feb 2015 Location: Oxfordshire / Milan Posts: 408 ![]() ![]() ![]() |
Sorry to bring this back up, but did anyone ever find a wheel carrier with a built in bumperette and a matching one for the other side or a wheel carrier compatible with existing bumperetes?
Grey110 Member Since: 20 Jun 2012 Location: Delft Posts: 35 ![]() ![]() |
Hi Yannis,
I have an Ex-Tec rear wheel carrier which fits with bumperettes. Only drawback is that it is expensive. See http://shop.ex-tec.de/product_info.php?products_id=6 Martin ![]() Previous 2003 Defender 110 Hardtop TD5 2004 Defender 110 Station Wagon TD5 - Libyan Sand 2005 Discovery 3 - V8 - Black |
I do not know of a swing away wheel carrier which has built in rear bumperettes/corner protectors. The best swingaway wheel carrier I have come across is the Nakatanenga stainless steel wheel carier. They have rear corner protectors which fit with thir wheelcarrier on 110's and 90's without mudflaps. Be aware that many cheap rear bumperettes will not work without modifications with most swingaway wheel carriers. Brendan |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 ![]() ![]() ![]() |
That is some Hinge Bracket ![]() ![]() ![]() |
