Home > Maintenance & Modifications > Tow electrics question
discocuzzy
Guys, the grey connector that is attached to the wiring loom of the vehicle has coroded badly over the winter.
I purchased some tow electrics with the male connector but i couldnt get the plugs together due to the excess corrosion..so...i cut the connector out, tisted the wires together, soldered the joints and then heatshrunk the connections exactly the same as if the connector was in place (same wire joins etc)....now my fogs dont work either on the landy or the trailer Thud
Any suggestions why this might be?, ive triple checked everything! You cannot teach stupid people to do clever things
Post #30526 22nd Apr 2010 8:50pm
Start again test as you go Thumbs Up
Post #30530 22nd Apr 2010 9:14pm
discocuzzy
bloody nightmare!...cant be arsed Ken, ill pay an auto lectrician i think You cannot teach stupid people to do clever things
Post #30531 22nd Apr 2010 9:30pm
Cibit
Bulbs and earths would be where I would start after fuses. It is always frustrating getting trailer lights going Good luck Thumbs Up 59 2.4 110 XS Utility
55 TD5 110 CSW Special Vehicle
Post #30535 22nd Apr 2010 10:15pm
discocuzzy
The dash light comes on to tell me the fogs are on but then i cant turn the switch off unless i pull the ignition Shocked You cannot teach stupid people to do clever things
Post #30588 23rd Apr 2010 1:19pm
K9F
Disco,
On Dgardel's second post on this thread you can download a set of diagrams...If they're the same as mine 'Exterior Lighting' section pages 57 and 58 show trailer socket arrangement. Save your money do a little checking....
http://www.defender2.net/forum/topic3051.html?highlight=
Good luck! Dog Thumbs Up Dog If you go through life with your head in the sand....all people will see is an ar5e!!
Post #30589 23rd Apr 2010 1:36pm
mse
Is it out of warranty - if mine is corroded when it comes back (i have the socket to connect under my desk) it will go in for work.
The option for them is a new loom - but i did spray WD 40 in there a year ago so hopefully Sheep Mike
Post #30638 24th Apr 2010 11:28am
