![]() | Home > Technical > What spline |
Easiest thing to do is take it off and count them to be 100% sure.
![]() Loads of threads on the subject but here's one of them that says the same as I have. http://www.defender2.net/forum/topic29112....d5+splines If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
bobtail Member Since: 17 Aug 2014 Location: Towcester Posts: 8 ![]() ![]() ![]() |
Cheers mate
And thanks to jaketravels for the link Seems to be 36 spline |
