Home > Puma (Tdci) > turbo wiring
Caterham
turbo wiring
Hi
To my mind the turbo has too many wires - what are they all for?
For those that have had a new turbo harness how was the problem diagnosed and if was intermittent how would you test it - what voltages etc would you expect to see in each wire?
Many thanks
Post #351336 13th Aug 2014 7:45am
martinfiattech
If you have a 2.4 and access to the 2007 wiring diagram try section 303-14. electronic engine controls. Turbo listed as actuator vane vgt. d363 .
whether it suits all models I don`t know, my electrics have been ok so far.
1. live connection
1. ground connection
3. signal wires, from turbo to ecu
5. wires in all
Check voltages across live and ground on turbo may be 5 (ish) volts ignition on. ecu voltage or 12 volts battery voltage.
Depending on set up of system.
Check continunity of signal wires on 200 ohms resistance from turbo to ecu. Don`t forget to disconnect battery if playing with ecu, you may need a fault code reader if you accidently make a fault code appear. don`t try to put battery voltage to the ecu or the turbo, it will get expensive.
I`ve seen it done, I have a man with a dead motor home because of this. £84,000 standing in his drive, all for the want of a phone call.
If you have access to good diagnostic kit you should be able to carry out an actuator test on the vgt unit to prove its readiness, some may even give you actual and desired figures to double check it. Excuse the spelling I`am better with spanners and wires.
Post #351690 14th Aug 2014 10:44pm
Caterham
Thank u very much.
Hopefully some spare time at the weekend to have a 'play'
Post #351693 14th Aug 2014 11:03pm
K9F
Thud Thud
Thud Thud If you go through life with your head in the sand....all people will see is an ar5e!!
Post #351700 15th Aug 2014 4:04am
ericvv
^^ Rolling with laughter
C's continuous trouble shooting gets you really excited, hey Thumbs Up
Why is it that my SVX is purring away like a cat without me doing anything other to it than have it frequently serviced? Something must be wrong I guess, let me start looking into this... Whistle You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #351701 15th Aug 2014 5:11am
Happyoldgit
Caterham wrote:
Thank u very much.
You have just summed up the root of most of your vehicular problems. Steve.
http://forums.lr4x4.com
Post #351713 15th Aug 2014 8:09am
Re: turbo wiring
Caterham wrote:
Hi
Many thanks
Snip some off, I'm sure they're just spare anyway.
Post #351719 15th Aug 2014 8:58am
munch90
disconnect it , at 30mph its not needed anyway , think of the mpg your get Rolling with laughter
I thought it was running ok , haven't you just been away in it ?
Post #351721 15th Aug 2014 9:02am
Caterham
Make that an extra large Rolling with laughter
Yes been away in it, doing quite a few miles in it but the pesky problem keeps coming and going......
Done this.......
Even so something is not right all the time which is frustrating Crying or Very sad
As mentioned elsewhere while the engine was ticking over I gave the engine harness a gentle wiggle here and there and the turbo actuator moved in / out - looked like a full movement.????? Only did it once and can't seem to get it to repeat.?
Post #351814 15th Aug 2014 6:45pm
munch90
exhaust might be full of cobwebs Rolling with laughter
Post #351849 15th Aug 2014 9:54pm
Caterham
Blast not again.......its just had the 6 monthly chimney sweep.
Post #351858 15th Aug 2014 10:16pm
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
Best thing you can do with an intermittent problem is to "let it develop" into a specific repeatable problem you have a fighting chance of finding the fault and sorting it.
Well that's what my journeyman used to say.................I think he was right (unless it was to do with brakes Rolling with laughter )
AndyR
Post #351876 15th Aug 2014 11:18pm
Happyoldgit
Nah, guesswork, idle fiddling and theories based on nothing much is more his style Laughing Steve.
Post #351906 16th Aug 2014 11:39am
Caterham
This hobby of dreaming up probs is possibly just about to cost me.
I'm on the verge of a new harness Crying or Very sad
Post #351907 16th Aug 2014 12:03pm
Are you sure you don't require a new turbo. Rolling with laughter
Post #351908 16th Aug 2014 12:06pm
