![]() | Home > Puma (Tdci) > turbo wiring |
...or a new vehicle, or more accurately your vehicle a new owner?
![]() Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6324 ![]() ![]() ![]() |
I hope not they replaced one......
![]() Perhaps that's it.....are these things twin turbo? |
ROBBONTHEROCK Member Since: 23 Jun 2014 Location: Aberdeenshire Posts: 637 ![]() ![]() ![]() |
What's the problem anyway, why are you needing to fiddle about with the Turbo?
Cheers AndyR |
he just likes fiddling
After watching the news at least it's only my Defender I like fiddling with...
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6658 ![]() ![]() ![]() |
What you may have done is inadvertently triggered the turbo into doing a "shutdown" vane clean.
There doesn't appear to be an intermediate connector between the turbo actuator and the engine ECU, so if you think you have a problem check each of the 5 terminals at the turbocharger connector. ![]() ![]() |
Brill
So it's a case of finding the relevant wires back at the ecu or knowing what to expect at the turbo end - either measuring the voltage or resistance from end to ejd ![]() |
