Home > Td5 > Blower fuse keeps going. |
benn Member Since: 12 Aug 2014 Location: southampton Posts: 3 |
just so you know the aux power
(fag lighter) is connected to the blower wiring so if you prob solving then maybe look in that direction? |
12th Aug 2014 9:11pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5729 |
Have you checked the drain on the heater intake system, to make sure it not keeping water in?
Andy |
12th Aug 2014 9:19pm |
DC101 Member Since: 01 Jul 2012 Location: Pudsey, West Yorkshire Posts: 260 |
Thanks for the heads up on the auxiliary socket.
Andy, I will definitely check on the drain, with someone else pointing me in that direction also. I wouldn't have thought to look there. Will take a look in the morning. Thanks. |
12th Aug 2014 9:33pm |
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 240 |
+1 for the drain,
Think it was Andy that solved this problem for me as well with the same solution Will Defender 90 XS TD5 (03 Reg) |
13th Aug 2014 7:40am |
Freypal Member Since: 23 Sep 2013 Location: Shropshire Posts: 271 |
Drain for sure. Check down there and see if the motor can spin freely. Most likely it is jammed solid. Common fault.
14th Aug 2014 1:26pm |
Hi,
Slightly embarrassed about relisting this thread as time has passed, but I still haven't resolved my blower issue ( too much to do, not enough time etc etc) I did check my drain plug, and as photo just about shows, there wasn't one anyway! So any further thoughts very welcome. With colder days and misty screens fast approaching , I need to be a bit more proactive now! Thanks Rob Click image to enlarge |
10th Sep 2014 8:45am |
