Home > Td5 > Blower fuse keeps going.
DC101
United Kingdom 2003 Defender 110 Td5 DCPU Epsom Green
Dear TD5 owners.
Any thoughts on a possible cause of this?
Well, the blowers weren't working and I discovered the fuse had blown. I replaced it (20 amp) turned the key and the blower worked, but when I started the motor to set off later on, the fuse blew again, so I suspect some TD5 foul play somewhere in the electricals.
I can live with out the blower at the moment, but the nights are getting longer and cooler...
Anything obvious to check?
Rob
Post #351296 12th Aug 2014 8:36pm
benn
United Kingdom 2002 Defender 90 Td5 HT Java Black
just so you know the aux power
(fag lighter) is connected to the blower wiring so if you prob solving then maybe look in that direction?
Post #351308 12th Aug 2014 9:11pm
landy andy
Have you checked the drain on the heater intake system, to make sure it not keeping water in?
Andy
Post #351310 12th Aug 2014 9:19pm
DC101
Thanks for the heads up on the auxiliary socket.
Andy, I will definitely check on the drain, with someone else pointing me in that direction also. I wouldn't have thought to look there. Will take a look in the morning. Thanks.
Post #351316 12th Aug 2014 9:33pm
Waldo
+1 for the drain,
Think it was Andy that solved this problem for me as well with the same solution
Will Defender 90 XS TD5 (03 Reg)
Post #351343 13th Aug 2014 7:40am
Freypal
United Kingdom 1992 Defender 90 200 Tdi HT Portofino Red
Drain for sure. Check down there and see if the motor can spin freely. Most likely it is jammed solid. Common fault.
Post #351570 14th Aug 2014 1:26pm
DC101
Hi,
Slightly embarrassed about relisting this thread as time has passed, but I still haven't resolved my blower issue ( too much to do, not enough time etc etc)
I did check my drain plug, and as photo just about shows, there wasn't one anyway! So any further thoughts very welcome. With colder days and misty screens fast approaching , I need to be a bit more proactive now!
Thanks
Rob
Post #356977 10th Sep 2014 8:45am
