Home > Maintenance & Modifications > Synchro works slick shift |
What does it do?
Is it just because you put the pivot point higher that your gearstick movement is shorter? Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
13th Aug 2014 8:02am |
taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663 |
Yeah, it just creates a short shift essentially. More distance between the 2 pivot points with some CNC spacer blocks in between.
Fairly simple, but IMO, fairly effective! |
13th Aug 2014 8:34am |
Till now I didn't think I needed that. If will have a look at my next drive. Roel
13th Aug 2014 9:03am |
tazmarkuk Member Since: 24 Jan 2012 Location: Birmingham Posts: 134 |
taazzukcb, did you have any problems contacting them, as I've tried on a numerous occasions and cant get through, I know there web site states they are out of stock of the slickshift.
13th Aug 2014 9:33am |
Not really had need to contact him directly. Just bought online and it turned up about a week later! Sorry that's not of much help!
14th Aug 2014 7:31am |
This is my rattle ...
Notice near the end I start playing with the stick to find the quiet spots ... Going to have a play with the bias springs over the weekend. I'm almost certain that should do it! May also do the plastic bush to as I just realised how it pops out ... Not how I expected or tried! |
14th Aug 2014 1:42pm |
Fullfat Member Since: 30 Apr 2014 Location: Lincolnshire. Posts: 271 |
Anyone manage to get a response from the seller?
Thanks |
24th Aug 2014 8:59pm |
jhnstap Member Since: 01 Apr 2013 Location: Bournemouth Posts: 73 |
E mailed Shabs 3 weeks ago, got a response straightaway-that they would be available in September-see they are available on his web site today, so just placed order
Price has risen to £75 but now includes nylon cup, and now allows you to keep your original gear stick I do my thing and you do yours. I am not in this world to live up to your expectations, and you are not in this world to live up to mine |
19th Sep 2014 6:55am |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2945 |
Seem like it's back albeit with £25 increase how does he justify that then
21st Sep 2014 4:50pm |
Materials have been improved by quite a bit and the machining of the shifter is far more than before (and to better tolerances) to allow the wear spring to be utilised as well as the original lever utilised. The nylon cup is also included in the price.
21st Sep 2014 5:46pm |
df1 Member Since: 06 Aug 2011 Location: Ireland Posts: 221 |
Got and fitted slickshift today, happy with quality and improvement in shifting.
No vibration as mentioned earlier. Takes a little bit of fiddling to get the bias springs how you want them, other than that straight forward fit. |
1st Oct 2014 5:56pm |
Fitted mine last week and must say it makes quite a difference to the gear change, its a very short precise gear change compared to the stick in the bucket gear change it was before.
Fitting only took 10 mins and I also had a play with the spring which took out the slack. Also repainted the gear shift as it was badly worn, Well worth the money in my opinion. |
1st Oct 2014 7:13pm |
Ken B Member Since: 17 Dec 2013 Location: Essex Posts: 106 |
Just fitted one of these today.. What a great improvement!!! i can really feel the tightness shifting up through the gears.
I do need to play with the adjustment as the downshift from 4th to 3rd has always been bad for me (assume it is just my gearbox) and now with a much shorter throw it feels a little more pronounced but that is because i was so used to where in amongst the bucket of options previously to push the stick.. Defender 90 TD5 County - You need only two tools in life: WD-40 and duct tape. If it doesnt move and it should: WD-40. If it moves and shouldnt: duct tape it. |
18th Feb 2015 6:07pm |
Paddocks stocking this now, more user friendly ordering process I'd imagine.
19th Feb 2015 7:00pm |
