Home > In Car Electronics > Amps query
Jonno1968
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Orkney Grey
Amps query
I have just bought a pair of 100w driving lamps. I think i need a separate relay switch to operate them but dont know what amps they will pull. The wiring kits state the amps but dont say what that is equivalent to in watts? Any ideas
Post #349043 2nd Aug 2014 5:42pm
90XS
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Corris Grey
To be exact, 8.33 amps each, ie 16.66 amps for the pair. You would probably want to allow a slight margin above this, so I would say 20 amps minimum. Hope this helps!
Post #349044 2nd Aug 2014 5:49pm
munch90
you will need a relay and as above Thumbs Up
Post #349049 2nd Aug 2014 6:04pm
Rickydodah
Re: Amps query
For future reference if you divide the wattage output by the voltage, in this case 12v it'll give you the amp draw. Thumbs Up
Post #349054 2nd Aug 2014 6:14pm
20A fuse with a 30A rated 4 Pin relay.
Vehicle Wiring Products will have all you want, I'd use thinwall cable too.
Post #349069 2nd Aug 2014 7:38pm
