Home > In Car Electronics > Amps query |
90XS Member Since: 01 Aug 2014 Location: Shropshire Posts: 76 |
To be exact, 8.33 amps each, ie 16.66 amps for the pair. You would probably want to allow a slight margin above this, so I would say 20 amps minimum. Hope this helps!
2nd Aug 2014 5:49pm |
you will need a relay and as above
2nd Aug 2014 6:04pm |
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 |
For future reference if you divide the wattage output by the voltage, in this case 12v it'll give you the amp draw. |
2nd Aug 2014 6:14pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20448 |
20A fuse with a 30A rated 4 Pin relay.
Vehicle Wiring Products will have all you want, I'd use thinwall cable too. |
2nd Aug 2014 7:38pm |
