Home > In Car Electronics > Single din cage defender 2008
jeeves
I've followed all advice on here and just fitted an alpine stereo and new speakers....only thing is the cage the alpine came in won't fit in the "hole"....,
Sorry if this has been mentioned before....any ideas if I need a defender specific cage ? :
Post #348865 1st Aug 2014 6:54pm
Have you taken out the metal brackets / pieces out each side. With a cage they shouldn't be there.
If they are gone it's a tight fit and should go in.
Or is it impossible? They should be universal 1 DIN in size.
Post #348869 1st Aug 2014 7:22pm
jeeves
It's the cage that doesn't fit the hole...the head unit fits in gone cage....seems the cage is just that too big for the hole the factory stereo came out of ??
Post #348880 1st Aug 2014 8:28pm
jeeves
Just found what you meant !!L popped them off and in it went....so to speak ....... : Laughing
Post #348886 1st Aug 2014 8:44pm
Wink
Post #348888 1st Aug 2014 8:58pm
Don't forget to carefully bend the tabs behind so the cage is locked into the dash.
When the HU goes in that'll then lock into the cage.
Post #348889 1st Aug 2014 8:59pm
