![]() | Home > In Car Electronics > Single din cage defender 2008 |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20650 ![]() ![]() |
Have you taken out the metal brackets / pieces out each side. With a cage they shouldn't be there.
If they are gone it's a tight fit and should go in. Or is it impossible? They should be universal 1 DIN in size. |
jeeves Member Since: 10 Jul 2011 Location: lancashire Posts: 91 ![]() ![]() |
It's the cage that doesn't fit the hole...the head unit fits in gone cage....seems the cage is just that too big for the hole the factory stereo came out of ??
Just found what you meant !!L popped them off and in it went....so to speak ....... :
Don't forget to carefully bend the tabs behind so the cage is locked into the dash.
When the HU goes in that'll then lock into the cage. |
