Home > Puma (Tdci) > 2.2 intercooler hose split - driveline smoothness
limbrickh
New Zealand 2012 Defender 110 Puma 2.2 XS CSW Santorini Black
Hi All, just FYI...
After going into limp mode (and associated MIL), my 2.2 2012 was diagnosed with a split intercooler hose. This is the hose on the left hand side of the vehicle (when in the driver's seat). This was replaced under warranty.
I have a suspicion that the split had been a gradual process and that the the engine management only went into limp mode when the split eventually became too bad. I think there had been a leak from new.
The reason I bring this up is that since the intercooler hose has been changed the vehicle has become so much smoother to drive. I don't think it is any more peppy (in fact weirdly, in some respects it feels less revvy) but low rev torque is definitely better and gear changes are so smooth it's almost like driving a Japanese hatchback (OK I might be exaggerating a bit). There is very little driveline shunt when going from trailing throttle to power-on. Previously there was a noticeable lag and clunk.
Most noticeable though is the behaviour in low range 1st. Previously I found the engine difficult to manage off road. Even with both feet off the pedals the Defender would slightly surge and bunny-hop while idling along. Now the power is predictable and smooth.
So if any of the problems above ring a bell with you - get your intercooler hose checked. A visual inspection is not good enough - the mechanic only found the split when he put his hand near the hose with the engine revving and felt escaping air.
Post #348764 1st Aug 2014 12:21pm
longman
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Orkney Grey
Hi,
The symptoms you describe are just like mine, juddery at low speeds and a light throttle. I'll check out the intercooler hose to see if this is the problem.
Thanks for the post.
Andy
Post #349796 5th Aug 2014 9:45pm
Hifonics
2013 Defender 110 Puma 2.2 USW Corris Grey
The intercooler hose is a recall, I just had mine replaced during its first service.
Post #349912 6th Aug 2014 11:54am
Jim_Bean
Post #349954 6th Aug 2014 3:30pm
Caterham
Hose problem is common but I don't recall any previously mentioning drive line smoothness....?
How is that related - anyone?
.....i need to check mine even though mine is a 2.4 Shocked
Post #349960 6th Aug 2014 4:07pm
PrivateB
Just had mine replaced when it went in for a fuel leak - gear changes are so much smoother now - Loved it before - Love it even more now....
Post #349978 6th Aug 2014 5:26pm
Caterham
Not doubting what you are saying but should we be surprised that gear changes are smoother and if not then why ie what causes the pipe to impact on gear changes?
Defender2495 did you have the engine mil light on or you just did the recall?
Post #349993 6th Aug 2014 7:11pm
PrivateB
Unsure as to why the hose change has had an impact on gear changes - as the turbo is doing almost nothing at those revs? - a great improvement in driveability though. No MIL or recall notification - they just changed it whilst it was there for the fuel leak.
Post #350018 6th Aug 2014 8:42pm
Caterham
to my mind that's bizarre Confused
would be interesting to understand how things have changed.....I wonder if the difference is the result of a map update which was done at the same time but perhaps not mentioned?
good to hear its going well which is the main thing.
Thumbs Up
Post #350031 6th Aug 2014 9:25pm
dilukabey
2009 Defender 110 Puma 2.4 SW Keswick Green
Blown Inter cooler hose
Mine had blown couple of months ago and replaced. It was the left hand side hose. Its not cheap either to get couriered to this part of the world from UK. Sad
Post #350082 7th Aug 2014 7:52am
