Home > In Car Electronics > is there a permanent live behind the rear speaker?
pob1968
There's quite a bunch of wires coming up from the floor in the rear speaker area, I have a tow bar with electrics so quite a few wires. I need a permanent live without having to run a fresh wire from the battery to the back of the truck. 110 Hardtop
Post #346319 19th Jul 2014 5:41pm
bear100
Behind the speaker panel on the right hand side is a purple and pink wire that is permanent live, many on here including myself have used it for a rear cigar power socket Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #346322 19th Jul 2014 5:47pm
bear100
Rear drivers side that is Very Happy 2016 Range Rover Autobiography 4.4 TDV8
Post #346323 19th Jul 2014 5:50pm
Has a white plastic plug.
Post #346360 19th Jul 2014 8:58pm
pob1968
Thank you very much 110 Hardtop
Post #346398 20th Jul 2014 7:09am
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
Seems to depend on the age of the vehicle.
After 2012, it's a bit more complicated.
Look at the first sticky under Maintenance and Modifications on here. 2003 Td5 110 Hardtop
Now a 2013 110 USW too.
Post #346407 20th Jul 2014 8:14am
pob1968
Yes, mine didn't have it so did it differently. I was taking power from the rear but done it differently now. Thanks for the advice. 110 Hardtop
Post #346439 20th Jul 2014 9:47am
Dale
United Kingdom 2001 Defender 110 Td5 Tomb Raider LE Bonatti Grey
Yes, just fitted this on mine!
Post #346492 20th Jul 2014 1:46pm
