![]() | Home > In Car Electronics > is there a permanent live behind the rear speaker? |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1960 ![]() ![]() ![]() |
Behind the speaker panel on the right hand side is a purple and pink wire that is permanent live, many on here including myself have used it for a rear cigar power socket
![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Rear drivers side that is
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20650 ![]() ![]() |
Has a white plastic plug.
pob1968 Member Since: 20 Apr 2014 Location: uk Posts: 239 ![]() |
Thank you very much 110 Hardtop
Macpaul Member Since: 25 Mar 2013 Location: SW Surrey Posts: 439 ![]() ![]() ![]() |
Seems to depend on the age of the vehicle.
After 2012, it's a bit more complicated. Look at the first sticky under Maintenance and Modifications on here. 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
Yes, mine didn't have it so did it differently. I was taking power from the rear but done it differently now. Thanks for the advice. 110 Hardtop
Dale Member Since: 14 Jul 2014 Location: Bristol Posts: 79 ![]() ![]() ![]() |
![]() Click image to enlarge Yes, just fitted this on mine! |
