Home > Maintenance & Modifications > Brunel Grey XS light surrounds extra fixing hole.....why ?
saltydog
2015 Defender 110 Puma 2.2 USW Corris Grey
I just bought an xs brunel grey light surround and grille set online from a very reputable supplier of parts.
The light surrounds have come with three fixing holes on them where my original standard black ones only have two.
Anybody have any ideas why they would have three holes on them .
Cheers, Salty LR Defender 110 XS Utility Wagon
LR Discovery 2.0 Sport HSE
LR Discovery 4 Landmark
Post #345053 14th Jul 2014 7:11am
david mitchell
Ireland 2003 Defender 90 Td5 HT Epsom Green
Apparently older side lights have 3 fixing holes compared to two for later version.
Post #345055 14th Jul 2014 7:28am
saltydog
Light surrounds
They were bought having being removed from a 2014 model Defender which is strange ! LR Defender 110 XS Utility Wagon
Post #345057 14th Jul 2014 7:33am
It's the other way around David, newer 2014 models have 3 holes and older have 2 - Don't know why though ?
Post #345059 14th Jul 2014 7:59am
munch90
I think its the other way round
older lamp( 2 piece lamp ) unit had 3 screw backing and the lense fitted to the backing by 2 screws
newer lamp ( lens and backing fixed together ) uses the 2 screws that used to hold the lens to hold the whole lamp
Post #345060 14th Jul 2014 8:14am
He's not talking about the lamps he's talking about the plastic surround that goes around the headlight and behind side light / indicator with the louvre in for the horn.
2014 model have three screw holes, 2013 and older have two screw holes Thumbs Up
Edit - to clarify, we are talking about the visible black screws that hold the plastic shroud on to the body Thumbs Up
Post #345061 14th Jul 2014 8:17am
david mitchell
Ok sorry, Embarassed
Post #345063 14th Jul 2014 8:22am
munch90
ah ok , never bothered to look at that on newer one
just someone said about older sidelights
Post #345064 14th Jul 2014 8:25am
if this is the two hole version, where does the third hole go?
Post #345076 14th Jul 2014 10:00am
K9F
With the indicator and sidelight securing the left hand side I wonder too where the third hole may be?
Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #345077 14th Jul 2014 10:02am
saltydog
Similar to this
This is what I have.. LR Defender 110 XS Utility Wagon
Post #345085 14th Jul 2014 10:48am
munch90
perhaps they think it will help to stop getting at alarm wiring !
Post #345086 14th Jul 2014 10:59am
90mojo
Here you go folks, 2014 Brunel, 3 holes
Embarassed sorry, no photo....
Post #345091 14th Jul 2014 11:22am
90mojo
Post #345092 14th Jul 2014 11:23am
rossy
When I replaced my black surrounds with a Brunel 2014 take off from LRI solutions recently I just ignored the extra hole. Dunno why its there but as the black ones were the same weight etc I figured it didn't matter and it doesn't Thumbs Up
Post #345410 15th Jul 2014 5:02pm
