![]() | Home > Maintenance & Modifications > Brunel Grey XS light surrounds extra fixing hole.....why ? |
david mitchell Member Since: 01 Jul 2012 Location: Meath Posts: 418 ![]() ![]() ![]() |
Apparently older side lights have 3 fixing holes compared to two for later version.
saltydog Member Since: 13 Mar 2012 Location: Aberdeenshire Posts: 91 ![]() ![]() |
They were bought having being removed from a 2014 model Defender which is strange ! LR Defender 110 XS Utility Wagon
LR Discovery 2.0 Sport HSE LR Discovery 4 Landmark |
It's the other way around David, newer 2014 models have 3 holes and older have 2 - Don't know why though ?
I think its the other way round
older lamp( 2 piece lamp ) unit had 3 screw backing and the lense fitted to the backing by 2 screws newer lamp ( lens and backing fixed together ) uses the 2 screws that used to hold the lens to hold the whole lamp |
He's not talking about the lamps he's talking about the plastic surround that goes around the headlight and behind side light / indicator with the louvre in for the horn.
2014 model have three screw holes, 2013 and older have two screw holes ![]() Edit - to clarify, we are talking about the visible black screws that hold the plastic shroud on to the body ![]() |
Ok sorry,
ah ok , never bothered to look at that on newer one
just someone said about older sidelights |
![]() if this is the two hole version, where does the third hole go? |
With the indicator and sidelight securing the left hand side I wonder too where the third hole may be?
![]() Treat every day as if it is your last....one day you will be right!! |
![]() This is what I have.. LR Defender 110 XS Utility Wagon LR Discovery 2.0 Sport HSE LR Discovery 4 Landmark Last edited by saltydog on 14th Jul 2014 11:45am. Edited 2 times in total |
perhaps they think it will help to stop getting at alarm wiring !
90mojo Member Since: 19 Mar 2014 Location: UK Posts: 175 ![]() ![]() |
Here you go folks, 2014 Brunel, 3 holes
![]() Last edited by 90mojo on 14th Jul 2014 11:23am. Edited 1 time in total |
![]() Click image to enlarge Here you go folks, 2014 Brunel, 3 holes |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
When I replaced my black surrounds with a Brunel 2014 take off from LRI solutions recently I just ignored the extra hole. Dunno why its there but as the black ones were the same weight etc I figured it didn't matter and it doesn't
