Home > Technical > Air con hot and cold
Page 2 of 2 <12
TallPaul
Standard on XS, option on base and country (says brochure nerd Laughing)
Wouldn't want this one anyway, not a real defender, the gutters were straight, the doors had no dents, it had underseal on the chassis....
Post #29905 15th Apr 2010 3:49pm
Shikari
Pakistan 2007 Defender 110 Puma 2.4 SW Santorini Black
Hi Gnasher,
Know this is an old post but, did u ever get that air con (cold on the left side n hot on the right side) prob solved? Jus beginning to hv that prob on my TDCi n wud be helpful if I drove into the dealers with a little knowledge Rolling Eyes
Appreciate ur input.
Post #241612 6th Jun 2013 11:37pm
ericvv
Shikari, read this thread.
http://www.defender2.net/forum/topic18844.html?highlight=fix
There is a fix, but it is a complete dash out job. I decided to live with this minor different left/right temp issue, and equalize left and right by use of the window. Thumbs Up
Edit: Put the LR fix for this issue in "My Gallery" under a section "Technical". You can download the PDF from there. Thumbs Up You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #241616 7th Jun 2013 4:25am
Shikari
Eric thanx a bunch. But still scratching my head with this Sad not sure whether to be glad that there is a fix or feel sick at the prospect of the dash out Big Cry Prob use the 2nd fix u recommended with the widow used for balance Thumbs Up
Post #242642 10th Jun 2013 9:24pm
Page 2 of 2 <12
