Home > Technical > Air con hot and cold |
Shikari Member Since: 12 Oct 2012 Location: Karachi Posts: 14 |
Hi Gnasher,
Know this is an old post but, did u ever get that air con (cold on the left side n hot on the right side) prob solved? Jus beginning to hv that prob on my TDCi n wud be helpful if I drove into the dealers with a little knowledge Appreciate ur input. |
6th Jun 2013 11:37pm |
Shikari, read this thread.
http://www.defender2.net/forum/topic18844.html?highlight=fix There is a fix, but it is a complete dash out job. I decided to live with this minor different left/right temp issue, and equalize left and right by use of the window. Edit: Put the LR fix for this issue in "My Gallery" under a section "Technical". You can download the PDF from there. You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
7th Jun 2013 4:25am |
Eric thanx a bunch. But still scratching my head with this not sure whether to be glad that there is a fix or feel sick at the prospect of the dash out Prob use the 2nd fix u recommended with the widow used for balance
10th Jun 2013 9:24pm |
