Home > Puma (Tdci) > running out of fuel |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
There is no easy steps on a puma ......
You'll need to remove and refill the fuel filter, then use an in-line hand pump to reprime the system ... And 'hopefully' it will restart without too much cranking . Failing that, injector unions need cracking off while cranking to purge the lines of air .... Enjoy Short answer is - DON'T RUN OUT!! Guns and Landrovers .... anything else is irrelevant. |
11th Jul 2014 7:45am |
ronwong Member Since: 28 Jun 2012 Location: Singapore Posts: 120 |
fuel filter? where is that?
where to pump the inline pump? what do you mean by injector unions needs cracking off? Sorry I am a beginer. I dont want to be doing this in the middle of no where. So an inline pump would need to be a tool to bring in expedition? |
11th Jul 2014 7:51am |
Given the Puma 2.2 has a strategy to prevent you running out of fuel - reduced power mode - it would be difficult if not impossible to not know it was happening:
From the Handbook: The vehicle is equipped with a system to prevent the fuel tank from emptying completely. When the fuel reaches a minimum level, the system will activate a reduced power mode (i.e. the engine will not run properly). This will be followed by the engine stopping in approximately 1.6 km (1 mile). This feature prevents the fuel system from running dry, which could cause damage to the vehicle. If the gauge indicates low fuel or the warning indicator illuminates, the fuel tank should be refuelled as soon as possible at the next filling station, with at least 4 litres (0.9 gallons) of fuel. If the system protection function has activated, the vehicle must firstly be refuelled, then restarted using the following procedure: 1. With the brake pedal depressed, turn and hold the engine start key and crank the engine for five seconds. 2. Release the key. 3. With the brake pedal still depressed, turn the key to crank the engine. The engine should start within approximately five seconds. Note: If the engine does not start, pause for ten seconds before repeating the procedure from the beginning. Do not crank the engine for longer than 30 seconds, or damage to the fuel pump may occur. Not sure why it states depress the brake pedal - anyone know? and from the Workshop Manual: LOW FUEL INDICATION AND RUN DRY STRATEGY The run-dry strategy is used to maintain the systems fuel prime at fuel run out. It ensures the minimum amount of fuel is always left in the swirl pot. The instrument cluster activates the yellow low fuel warning light (next to the fuel gauge) with 17% of fuel remaining in the tank. The fuel gauge will indicate empty with 12% of fuel left in the tank. With 6 liters left in the tank the run-dry strategy will be invoked. An engine mis-fire will be induced for approximately 1 mile after which the engine will be shut down. The engine can be re-started in mis-fire mode and will continue to run for a further mile until the engine shuts down again. This can be repeated until the fuel suction port in the tank is uncovered and causes engine fuel starvation and loss of prime. Re-starts after run-dry shut down are not recommended. |
11th Jul 2014 8:11am |
Mjibex Member Since: 21 Mar 2013 Location: Reading Posts: 283 |
To answer the OP:-
2.2 is no worry - it will self prime. 2.4 is more complicated - it won't self prime - self previous posters info. mark. |
11th Jul 2014 7:04pm |
FR-F1 Member Since: 10 Jul 2014 Location: Carnoules Posts: 2 |
I'm not totaly sure that the ID4 2.2 will self prime.
I have the 2012 workshop manual from topix for the 2.2 and the method to prime the engine is still to use the hand pressure pump (special tool 310-110). So maybe there is a evolution on the very last models but not for the late 2011 and 2012 models. |
11th Jul 2014 8:19pm |
I wasn't aware the 2.2 would self prime either.
I know It's got the 'Won't run out' technology .. But if you keep going and do run it out ........... Had it happen on 2.2 Transits once or twice ... Hell of a job priming back up. Guns and Landrovers .... anything else is irrelevant. |
11th Jul 2014 9:22pm |
I was lead to believe that:-
1. The 2.2 defender has a lift pump, as well as main injection pump. 2.4 has just the main injection pump. 2. Change a filter on a 2.4 and it needs priming, whereas 2.2 doesn't. I've not had to change mine myself yet though. |
11th Jul 2014 10:26pm |
ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731 |
According to the 2.4 manual (German version) you can't run the system dry unless you have a fuel leak. Page 64 of the manual says at a certain minimum fuel level (never quite figured out how much), the engine goes into a reduced power mode in order to stop the fuel system pegging out. You can then limp 1.6 Km before it shuts itself down and waits for fuel.
You then have to put at least 4 L diesel in and do the fancy key twisting/brake pedal pushing to get it going again. Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
12th Jul 2014 5:51am |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
Because your computer dosn't have a keyboard, this is the car version of ctrl+alt+del. There are loads of them for modern cars all of which have different resets or messages for the computer. |
12th Jul 2014 12:16pm |
most owners manuals tell you to push the brake pedal for the simple reason it might be in gear
12th Jul 2014 12:33pm |
All these information I very useful. Thanks all. Which means, when it goes into some sort of limp mode, you should ready off the engine and walk to buy some fuel instead of trying to drive there. And if still dumb enough to still go on, it can go about 1mile till the engine die on me. And they fuel lines at this time is still primed with fuel mostly. So fill up and do the cycle thing so get everything back.
14th Jul 2014 2:34am |
That's for the 2.4 - better check if it's the same for the 2.2 Tell someone you love them today because life is short.
14th Jul 2014 6:02am |
I doubt I will ever be far enough from filling station to worry , but if I thought I might be then I would carry spare fuel ( 5 litres )
only thing I do carry is a spare fuel filter and with that I got one of the metal camping fuel bottles with a litre of diesel for priming filter |
14th Jul 2014 8:38am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17387 |
If you extend the tank breather into the rear body (the most sensible place for it anyway) then priming the 2.4 fuel system becomes very easy. Simply open the bleed valve in the engine bay and get an assistant with good lungs to blow into the breather pipe until bubble-free fuel emerges in the engine bay. Simple!
14th Jul 2014 9:53am |
