Home > Td5 > Lazy throttle pedal |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10382 |
It was modified to keep it out of harms way, so cable ran to the 'pot'. This is just normally at the side of the pedal.
20th Feb 2015 1:53pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5707 |
Early ones were two track later ones were three track. Mines a later three track. Shout if you want to try it. |
20th Feb 2015 2:34pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5843 |
Thanks LA. Will do, how ever I think mine is a 2 track? 1999 Defender TD5 110
20th Feb 2015 2:40pm |
Finally got around to removing the cubby box and found the hi/low plug. Bridged the contacts and throttle pedal still lazy. Next is some contact cleaner on the throttle pedal and see what gives. 1999 Defender TD5 110
21st Mar 2015 9:49pm |
