Home > Td5 > Lazy throttle pedal
Page 2 of 2 <12
roel
The High low switch will change the throttle response.
I would investigate that further. If I remember right the throttle will be programmed for road behavior (quick response) if the connection is open. If the connection is closed It would be in Off-road mode so less sensitive response.
So check with a Nanocom or similar what the ECU thinks in what position it is. Roel
2003 90 Td5 (2009-now)
Post #400581 20th Feb 2015 1:23pm
It was modified to keep it out of harms way, so cable ran to the 'pot'. This is just normally at the side of the pedal.
Post #400589 20th Feb 2015 1:53pm
landy andy
excossack wrote:
The spare potentiometer could be a good move, is this the same across all years?
Early ones were two track later ones were three track. Mines a later three track. Shout if you want to try it.
Post #400594 20th Feb 2015 2:34pm
excossack
Thanks LA. Will do, how ever I think mine is a 2 track? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #400595 20th Feb 2015 2:40pm
excossack
Finally got around to removing the cubby box and found the hi/low plug. Bridged the contacts and throttle pedal still lazy. Next is some contact cleaner on the throttle pedal and see what gives. 1999 Defender TD5 110
Regards
John M0VAZ
Post #409745 21st Mar 2015 9:49pm
Page 2 of 2 <12
