Home > Maintenance & Modifications > Am I doing this right Info wanted on headlight loom upgrade
gilarion
Am I doing this right!
I have Just obtained two sets of wiring looms to upgrade my headlights from Ebay
The looms contained two relays which because they came from China I will replace with known quality ones.
My question is am I right in thinking that all I have to do is run the live wire in the loom direct from the battery (fused) and then remove the existing H4 connector and replace with the H4 connector on the end of the new loom, then fit the three pronged male connector also on the new loom into the original H4 connector and find a suitable good earth for the earth wire and job done!
Or am I missing something important. I intend to run a separate new loom to each headlight even though the new loom has fitting for both headlights, that’s why I bought two looms, I will just strip out the extra wires and relay out of the each loom.
Post #342241 2nd Jul 2014 1:28pm
jimbob7
Yeah,that sounds about right,as easy as that,fwiw, I ran a live direct from the alternator. Pov.spec,ftw. 2006, 110,TD5.
Post #342265 2nd Jul 2014 3:14pm
VeeTee
Netherlands
^ what he said. I also fitted the live wire direct to the alternator. Cheers, Vincent
MySite
Post #342322 2nd Jul 2014 6:48pm
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
I've got one on the shelf ready to be fitted (along with a lot more stuff when time permits!) and the instructions say to connect direct to the alternator. Other than that, do exactly what you plan.
For those that have one already fitted, is the benefit perceivable? If its really good i'll bump it up my to do list.
Thanks
Post #342545 3rd Jul 2014 3:01pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
I made my own up, using decent gauge wire, so can't comment on these ebay sets, but otherwise, yes, there was a very noticeable difference on mine. Largely because lights were receiving the correct voltage, not 10-11 volts as it was previously.
And the switch shouldn't now melt
Post #342547 3rd Jul 2014 3:04pm
jimbob7
Fitted Crystals, loom and Nightbreakers when I did mine,so can't comment on wiring loom mod.But as whole, yes a lot better,although I only used them for the first time last night,lol,roll on winter and dark nights Rolling Eyes . Pov.spec,ftw. 2006, 110,TD5.
Post #342561 3rd Jul 2014 4:34pm
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
Loads better, I had ordered the Chinese ones but they never turned up. I made my own up and ran straight from the alternator, so now rather than 10 and a bit volts I get over 13 at the connector, almost a 30% rise in voltage and loads more light. They are now white rather than dull yellow Thumbs Up Thumbs Up 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #342614 3rd Jul 2014 8:26pm
