Home > Td5 > Diff lever.
ozzy57
2002 Defender 110 Td5 CSW Alveston Red
Diff lever.
Following on from my "help I've done me front diff" thread, it turns out my diff lever has too much free play (careful John).
How do I adjust this? I have been through all the manuals I have, it's either not in there or I've missed it (probably the latter). I can only find info on the high/low part of it. It wasn't me!
Post #340915 26th Jun 2014 8:58am
K9F
I can only speak for the Puma when I swapped mine out for a replacement one. I may also be off the mark for your scenario. If yours is similar and you can gain access by removing the 'tunnel' access panel all will become clear. There is an adjustable turnbuckle that you can adjust to take up any free play.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #340916 26th Jun 2014 9:15am
JWL
If I remember correctly, there's not much scope for adjustment but on the pivot point of the linkage that is parralel to the main gearbox, if you take the pivot pin out and pull the linkage out of the way, there should be adjustment on the "peg" that sits out of the gearbox casing so you can push the pivot point away from the gearbox or pull it in tighter. This should help, not mine but you can see the threaded "peg" going into the gearbox casing
Post #340917 26th Jun 2014 9:15am
Kevzeboy
United Kingdom 2011 Defender 110 Puma 2.4 USW Indus Silver
There will be a little nut that has come loose on the linkage.
Happened to me and while green laning. Was a pain but easy to fix.
Post #348120 28th Jul 2014 8:27pm
