Home > Technical > aux feed |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
If I'm not mistaken the purple black wire behind the rear o/s speaker is referred to as the aux?
Does this get used for anything - I presume not from the factory? Can anyone confirm if it's the aux fuse 20a under seat and most importantly if that 20a feeds anything else ie if I pulled that fuse out would it affect anything else? Many thanks |
22nd Jun 2014 9:55am |
Yes, that's the aux feed. IIRC it gets used for the optional work light, although the connector will also plug directly into an OEM 12v socket.
Yes, you've got the right fuse. The supply also feeds power to the towing electrics, so if you pull the fuse but have the 12S or 13 pin electrics fitted then some things won't work. There are lots of threads on using this connection so I'm sure that a quick search will tell you all you need to know Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
22nd Jun 2014 10:12am |
Caterham, all you need to know...
http://www.defender2.net/forum/topic20319.html You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
22nd Jun 2014 10:21am |
Oscar Romeo Member Since: 16 Apr 2014 Location: South Yorks, the pinnacle of all human achievement Posts: 121 |
Top cheap mod!
22nd Jun 2014 10:50am |
