Home > Technical > aux feed
Caterham
aux feed
If I'm not mistaken the purple black wire behind the rear o/s speaker is referred to as the aux?
Does this get used for anything - I presume not from the factory?
Can anyone confirm if it's the aux fuse 20a under seat and most importantly if that 20a feeds anything else ie if I pulled that fuse out would it affect anything else?
Many thanks
Post #339780 22nd Jun 2014 9:55am
Yes, that's the aux feed. IIRC it gets used for the optional work light, although the connector will also plug directly into an OEM 12v socket.
Yes, you've got the right fuse. The supply also feeds power to the towing electrics, so if you pull the fuse but have the 12S or 13 pin electrics fitted then some things won't work.
There are lots of threads on using this connection so I'm sure that a quick search will tell you all you need to know Thumbs Up Darren
Post #339783 22nd Jun 2014 10:12am
ericvv
Post #339784 22nd Jun 2014 10:21am
Oscar Romeo
Location: South Yorks, the pinnacle of all human achievement
England 2010 Defender 110 Puma 2.4 XS CSW Rimini Red
Top cheap mod! Bow down
Post #339790 22nd Jun 2014 10:50am
