![]() | Home > Td5 > Diesel in Oil |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
Checked the oil on my defender today and it was just over full and rather thin considering I changed it 150 miles ago. whenever I change it I always do it to midway on the dipstick, so obviously its rising.
I changed the injector seals about 4,000 miles ago (using the correct tool and genuine seals etc) so my question is - could the injector seals have gone again/I haven't fitted them correctly? OR has the head cracked? if its the former then I'm to too fussed, if its the latter then I have one hell of a bill coming my way! there isn't any difference in starting or drivability if that helps in remote diagnosis. any suggestions much appreciated ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
When you say seals, did you do the copper washers and rubber O rings ?
Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
I did yes
I guess you cleaned the seats in the head before putting the injectors back ?
I would have thought that if the seals were a problem it would have shown before this. I had mine done last year along with a new turbo and full oil change. I panicked a bit a few weeks later as the oil level seemed to rise. The smell test on the dipstick did not seem like diesel so I left it for a few weeks, checking the level regularly and it settled down eventually. Any change in water level or smoke on start up ? As yours is a 15P engine you 'should' have the metal head locating pins but there does not seem to a definitive answer to what engine numbers onwards these were fitted to. I would be tempted to pull the injectors again and see if there is any sign to damage to the seals (you will have to fit new ones again) before ripping the head off to get it pressure tested. If you want it checked out I know a good Indie in Wellington who works on mine. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! Last edited by bob neville on 18th Jun 2014 7:44pm. Edited 1 time in total |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 821 ![]() ![]() ![]() |
I've been thru this, as above change the seals first and if you driving it change the oil often. I was getting 3lts of diesel in the sump every 2weeks.
When you doing the seals again look very closely at cylinder no1 injector seat, as its a know week spot, I have attached a pic. of what mine looked like. If you open the picture you can see the crack on the right of the port at about 2 o'clock as you look at it. This head also passed a pressure test... ![]() Nigel ![]() Click image to enlarge |
Blacktt600 Member Since: 30 Nov 2013 Location: Leeds Posts: 125 ![]() ![]() ![]() |
As above, seals replaced ( cheaper option) but unfortunately it turned out to be the head. On the plus side you end up with a very clean internals, down side it costs 2k+ for a new head.
Martin |
Well the earliest I can re do the injectors is next weekend I'm going to the Peak District in it this weekend, looks like I'll have to take it super steady. Hopefully the zx1 treatment will do something
Just be prepared to drain a couple of pints off. I checked mine every 100 mile and i managed 500 mile before draing 4 pints out, at that point it was obvious it was serious.
Martin |
Cancled the 500 mile trip as it's too much of a risk towing a loaded box trailer. My next question is, if it is the head. Do I buy a new one or have my one repaired? No point in having a second hand one as the history of it will be unknown. Any thoughts? 2002 90 Td5 Station Wagon
I would go for the AMC one from Turner Engineeering, not heard anything bad about them
![]() Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
IMO Turners rebuild Land Rover engines better than LR built them in the first place.
Just finished my defender, changed all the seals again after very carefully cleaning and inspecting the injector chambers for cracks.
Couldn't see anything with a strong magnifying glass. Put it all together very carefully and everything was surgically clean. Hopefully that cures it but I'm not holding my breath, if the oil level starts rising now then it's the head for sure ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Podrob Member Since: 20 May 2012 Location: Co Derry, N Ireland Posts: 31 ![]() ![]() ![]() |
Had same problem on mine a few years ago. Replaced seals didn't sort it. Got a new AMC Head and have had no issues since. I could not see any cracks on the old head when examined
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5884 ![]() ![]() ![]() |
That's the head I have on mine now 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
