Home > My Defender > Pete's 2008 110 DCPU |
david mitchell Member Since: 01 Jul 2012 Location: Meath Posts: 418 |
Welcome , nice 110 double cab. You can't go wrong with green.
15th Jun 2014 10:59pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20367 |
Now you've done it! Welcome to the site, mad as a box of frogs on here. |
15th Jun 2014 11:13pm |
GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555 |
Looks tidy! I always love the look of a 110 DC without a back on! An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
16th Jun 2014 5:26am |
PCA42 Member Since: 15 Jun 2014 Location: Church Stretton Posts: 468 |
Thanks for the welcome chaps
16th Jun 2014 5:29pm |
Fabio Member Since: 05 Aug 2011 Location: Somerset Posts: 589 |
Welcome!!
17th Jun 2014 6:44pm |
On Saturday afternoon, I spent some time with the Autoglym. At first I went over it with Super Resin Polish, and then sealed the paintwork with their sealant. I shall give it a coat of wax at somepoint soon! Never had such a shiney Landy
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge This photos shows the First Four glovebox conversion fitted (still need to play with it to get the shut line flusher), Britpart grey cubbybox (what can go wrong with a cubbybox, even if it's a blue-box product?!), MudUK seat rail extensions, full floor mat set and seatbox corner protectors from YRM Solutions. I also fitted a front diff guard (I did buy a pair, but then realised it wouldn't fit the P38/Wolf rear axle ), and my First Four steering guard that I took off my old 90. I did order JATE rings, but they sent me the wrong, narrower ones that won't fit around the steering gaurd I also have a Mantec Snorkel on order which I will fit, and later this week it is going for a full service and to have a couple of minor problems sorted out which I am not sure on how to fix myself. However, I am already enjoying owning a TDCi DCPU, and can't wait to do more with it whether it modifications/additions, or adventures! Can anyone give me an idea on what springs I could fit to the front of the vehicle? I would like to raise the front up a little to level it up to the rear (I know the 'nose down' stance is typical of a 110), but I'd like to keep the spring rate the same without going heavy duty (I don't plan to fit my winch on the front at this stage)? Would 90 rear springs work or something like that? Pete 2010 Discovery 4 GS TDV6 1972 Series III 88" 2.25P |
23rd Jun 2014 5:35pm |
Early Puma 90XS came with HD suspension that gave you a natural 1" lift over standard so make sure you get the right ones if you don't want to go HD at this stage. Lovely looking truck.
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
23rd Jun 2014 5:59pm |
kipperthedog Member Since: 27 Jun 2013 Location: Down South Posts: 403 |
I have OE HDs on the front of mine, 90 rears and 110 HD fronts are the same spring.
Click image to enlarge Ha I have now remebered how to insert the picture properly! Will take a side on this evening for you. Last edited by kipperthedog on 24th Jun 2014 4:18pm. Edited 7 times in total |
24th Jun 2014 7:38am |
.....double post .....
24th Jun 2014 7:42am |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
Lovely looking truck! Some interesting mods... Welcome to the forum Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
24th Jun 2014 9:14am |
Cheers chaps! Looks like 90 rears/110 HD fronts are the way to do it then Pete
24th Jun 2014 3:33pm |
I have been happy with this. The spring rate is the same as the stiffer of the 2 rates on standard springs and my old standard springs had sagged through the lighter rate coils so I didn't notice that much difference. There is still a bit of nose down with 110HDs but you could fit spring isolators at the same time, which gives a little vibration damping, though I didn't bother myself.
24th Jun 2014 4:11pm |
Definitely will be considering the 90 rear springs kipperthedog!
Today, I adjusted the lock stops and boy what a difference it makes I can actually get around some of the corners now without mounting the kerb! I also fitted rear bumperettes from GDI Products. They are not that heavy duty compared to the ones I've had in the past, but I only wanted them on as a first line of defense for reversing into things or other muppets driving into me so the lights don't get smashed up. They'll probably need painting in the future too as the powdercoating isn't exactly very durable like most powdercoated things you get these days. Click image to enlarge Click image to enlarge Click image to enlarge I think I shall have to cut them down a bit too as they protrude out the sides quite a long way, and may get caught up on things. However, for the price they're sound I think I shall get some tree/rock sliders to match at somepoint. Pete 2010 Discovery 4 GS TDV6 1972 Series III 88" 2.25P |
1st Jul 2014 9:50pm |
Today I was near Craddocks, so decided to drop in for a set of 235/85 Cooper ST Maxx tyres, since I was fed up with driving around on the frankly sh** Grabbers and had previous excellent experience with them. It drives like a different truck now, and does not drift left anymore
Click image to enlarge Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Pete 2010 Discovery 4 GS TDV6 1972 Series III 88" 2.25P |
29th Aug 2014 1:53pm |
