![]() | Home > My Defender > Pete's 2008 110 DCPU |
david mitchell Member Since: 01 Jul 2012 Location: Meath Posts: 418 ![]() ![]() ![]() |
Welcome
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
Now you've done it! ![]() ![]() ![]() Welcome to the site, mad as a box of frogs on here. ![]() |
Looks tidy! I always love the look of a 110 DC without a back on!
![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
PCA42 Member Since: 15 Jun 2014 Location: Church Stretton Posts: 468 ![]() ![]() ![]() |
Thanks for the welcome chaps
Fabio Member Since: 05 Aug 2011 Location: Somerset Posts: 589 ![]() ![]() ![]() |
Welcome!!
On Saturday afternoon, I spent some time with the Autoglym. At first I went over it with Super Resin Polish, and then sealed the paintwork with their sealant. I shall give it a coat of wax at somepoint soon! Never had such a shiney Landy
![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge This photos shows the First Four glovebox conversion fitted (still need to play with it to get the shut line flusher), Britpart grey cubbybox (what can go wrong with a cubbybox, even if it's a blue-box product?!), MudUK seat rail extensions, full floor mat set and seatbox corner protectors from YRM Solutions. I also fitted a front diff guard (I did buy a pair, but then realised it wouldn't fit the P38/Wolf rear axle ![]() ![]() I also have a Mantec Snorkel on order which I will fit, and later this week it is going for a full service and to have a couple of minor problems sorted out which I am not sure on how to fix myself. However, I am already enjoying owning a TDCi DCPU, and can't wait to do more with it whether it modifications/additions, or adventures! Can anyone give me an idea on what springs I could fit to the front of the vehicle? I would like to raise the front up a little to level it up to the rear (I know the 'nose down' stance is typical of a 110), but I'd like to keep the spring rate the same without going heavy duty (I don't plan to fit my winch on the front at this stage)? Would 90 rear springs work or something like that? Pete 2010 Discovery 4 GS TDV6 1972 Series III 88" 2.25P |
Early Puma 90XS came with HD suspension that gave you a natural 1" lift over standard so make sure you get the right ones if you don't want to go HD at this stage. Lovely looking truck.
![]() Treat every day as if it is your last....one day you will be right!! |
kipperthedog Member Since: 27 Jun 2013 Location: Down South Posts: 403 ![]() ![]() |
I have OE HDs on the front of mine, 90 rears and 110 HD fronts are the same spring.
![]() Click image to enlarge Ha I have now remebered how to insert the picture properly! Will take a side on this evening for you. Last edited by kipperthedog on 24th Jun 2014 4:18pm. Edited 7 times in total |
.....double post
Lovely looking truck! Some interesting mods... Welcome to the forum
Cheers chaps! Looks like 90 rears/110 HD fronts are the way to do it then
![]() 2010 Discovery 4 GS TDV6 1972 Series III 88" 2.25P |
I have been happy with this. The spring rate is the same as the stiffer of the 2 rates on standard springs and my old standard springs had sagged through the lighter rate coils so I didn't notice that much difference. There is still a bit of nose down with 110HDs but you could fit spring isolators at the same time, which gives a little vibration damping, though I didn't bother myself.
Definitely will be considering the 90 rear springs kipperthedog!
![]() Today, I adjusted the lock stops and boy what a difference it makes ![]() I also fitted rear bumperettes from GDI Products. They are not that heavy duty compared to the ones I've had in the past, but I only wanted them on as a first line of defense for reversing into things ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge I think I shall have to cut them down a bit too as they protrude out the sides quite a long way, and may get caught up on things. ![]() ![]() 2010 Discovery 4 GS TDV6 1972 Series III 88" 2.25P |
Today I was near Craddocks, so decided to drop in for a set of 235/85 Cooper ST Maxx tyres, since I was fed up with driving around on the frankly sh** Grabbers and had previous excellent experience with them. It drives like a different truck now, and does not drift left anymore
![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 2010 Discovery 4 GS TDV6 1972 Series III 88" 2.25P |
