![]() | Home > Td5 > heavy duty cv joints and half shafts front axle 110 shops |
Swollock Member Since: 16 Mar 2013 Location: Wellingborough Northants Posts: 262 ![]() ![]() ![]() |
I was given some interesting advice on fitting heavy duty parts. Upgrading parts only transfers the failure to the next bit of the drive train, upgrade the half shaft then the diff breaks, so leave the half shafts alone as the are quicker and easier to change.
I am sure that this will generate some debate. 2008 Defender 110 XS CSW Volvo S60 T8 Triumph 1200 Rally Explorer G0UBX |
shyy Member Since: 18 Feb 2013 Location: TLV Posts: 8 ![]() ![]() |
I dont agree with this theory
Over the last 14 years i'm driving with rear maxidrive diflook and heavy duty shafts. i never broke anything until last week In the front axle i have mcnamara diff lock its heavy duty differential and ashcroft heavy duty ring and pinions replacing the front half shafts in the middle of the Terrain is Unwanted and Uncomfortable. 1999 Defender TD5 110 |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6126 ![]() ![]() ![]() |
Could be worth trying KAM if Ashcroft are out of stock?
http://www.kamdiffs.com/products-2/heavy-duty-shafts/ |
